Hyperfrog
Why does my Apple IIe says "Apple ][" on its boot screen instead of "Apple //e" like I've seen on some pictures. Is there a switch or a key combination to make it boot as a IIe?
Thanks,
Christian
Thanks,
Christian
It's not enhanced.
Or you may just have an Apple //e case with an Apple ][ motherboard inside.
That's when the ROM was updated to say "//e" instead of "][", yes.So only the Enhanced //e displays "Apple //e" on its boot screen?
Actually Apple II autostart ROM would display "APPLE ][" (all caps.) Unenhanced IIe uses lowercase, and enhanced IIe uses slashes for roman II.Or you may just have an Apple //e case with an Apple ][ motherboard inside.
BTW, is your model an early ][e (one with white lettered keys and can't support double hi-res graphics?).
BTW, is your model an early ][e (one with white lettered keys and can't support double hi-res graphics?). If so, these are harder to find. http://www.reactivemicro.com/
