RickNel
I wish I could find the discussion+pinouts I used back in the day, but this comes close. One of the things I recall having to do with the modems I used on the IIgs/Macs is set the DTR dip switch to 'ON' at all times.
Null modem wiring: http://groups.google.com/group/comp.sys.apple2/msg/202354d6aef4a221
Thanks - the pinouts at this link are the standard Mac miniDin to D25 adapter that I am already using, minus the null-modem second adapter.
The null-modem pinout listed is not the standard one as far as I know - this one shorts RTS and CTS together at both ends and delivers them as "Carrier Detect" (D25 pin 8 ) - which looks counter-intuitive to me.
Standard null-modem just crosses RTS and CTS (D25 pins 4 and 5 ), which I've already tried with no success (connection never establishes).
I'm talkng now about direct serial-to-serial, without modem. In the modem scenario, there are AT command to tell the modems which signals to expect or ignore (eg DTR).
Apple forum post that I found says when using a Mac RS422 serial to RS232, miniDIN pin 6 should NOT be connected to 20 or to anything, and my experiments confirmed that. Pin 6 is a unique RS422 signal.
I have DTR (20) tied to RTS (4) on the D25 end, and that's the best result so far.
Rick
