DEC used the same edge card connector finger design of 18 connections, double sided, 36 connections per blade very early on.
Starting with the individual one blade and two blade flip chip modules, thru the two/four/six blade UNIBUS, QBUS, and OMNIBUS modules.
They are all mechanically compatible, and that is all. They are NOT universally electrically compatible. Power and ground connections do differ.
The answer to your particular question is a resounding NO. Don't even try it. There are power supply and ground connection incompatibilities.
