I have a PowerMac 5260/120, 32MB RAM, running System 7.6
I want this to get onto my Ethernet network, and I recently attained a bunch of stuff for doing that. I hooked an EN-SC, which is a SCSI-Ethernet adapter, up to the SCSI port of the Mac, and installed the drivers. I then rebooted, and all input stopped working (keys & mouse button) except the cursor movement. Even if you disconnect the device, the input is broken until a reboot. If you boot the machine without the device, things are fine, and if you hook it up afterwards, it errors when you try to switch to EtherTalk, and reverts to LocalTalk.
I don't know how to fix this. I've emailed their support, but who knows if they can/will help, as this is an old device. It was brand new in shrink wrap, so there's nothing wrong with it. I'm a bit nubby with Mac, so perhaps I'm just missing something.
Thanks.
Edit: Update: I tried my other PowerMac, and a second EN-SC device, both to no avail. As a side note, the macs don't seem to pick up the device when I plug the SCSI cable into the other port, but they don't have the issues that way either. Odd.
Thanks.
