;* .-= MOUSE PC1 Project =-. *
;* Int33h mouse hook for PC1 - NECV40 0.97 by Simone Riminucci (C) 2016 *
;* Started: 29.11.2016 *
;* Last updated 21.02.2017 *
;* Tested on: OLIVETTI PRODEST PC1 (NEC V40 XT, 512/640kB) *
;* Only 1904 byte Resident! *
;* Compile with NASM (186 code) *
;* Hardware Mouse pointer using YAMAHA V6335D special registers ! *
CPU 186 ;code compatability
;%define DEBUG
;%define CALL_OLD_INT33
BIOS_DATA_SEG EQU 40h
driverversion equ 303h ;imitated Microsoft driver version
%include "constant.inc" ; Stuff that never changes.
%macro TEST1 2 ;test 1 bit (n. CL). ZF is set if bit is zero.
; out CY=0 V=0, ZF as needed
%ifn %2=CL
%error "Only CL as second parameter"
%endif
db 0Fh
%if %1=AL
db 10h
db 0C0h
%elif %1=AX
db 11h
db 0C0h
%else
%error "Invalid Parameter"
%endif
%endmacro
%macro SET1 2 ;set 1 bit (n. CL). if ZF is set the bit go to zero.
%ifn %2=CL
%endif
db 0Fh
%if %1=AL
db 14h
db 0C0h
%elif %1=AH
db 14h
db 0C4h
%elif %1=AX
db 15h
db 0C0h
%else
%endif
%endmacro
;************** Program header ***************************************************
ORG 100h ;use if compiling .COM file
jmp start
cmdlineflags db 0
KeyStatus db 0
Old_INT08 dd 0 ;old INT
Old_INT09 dd 0 ;old INT
%ifdef CALL_OLD_INT33
Old_INT33 dd 0 ;old INT
%endif
Old_INT09_MONK dd 0 ;old INT
Already_in_user db 0
Cursor_Flag db 0FFh
MIN_HRange dw 0
MAX_HRange dw 639
MIN_VRange dw 0
MAX_VRange dw 199
Hor_Ratio dw 8
Vert_Ratio dw 8
X_Mult_Ratio dw 8
Y_Mult_Ratio dw 8
CenterX dw 15
CenterY dw 15
H_Mickey_Count dw 0
V_Mickey_Count dw 0
Max_speed_D2 dw 2
Max_Speed_D dw 35h
Button_Status dw 0
LB_Count_press dw 0
LB_PosX_last_press dw 0
LB_PosY_last_press dw 0
LB_Count_releases dw 0
LB_PosX_last_release dw 0
LB_PosY_last_release dw 0
RB_Count_press dw 0
RB_PosX_last_press dw 0
RB_PosY_last_press dw 0
RB_Count_releases dw 0
RB_PosX_last_release dw 0
RB_PosY_last_release dw 0
shift_X_Pos db 1
shift_ratioX db 0
shift_ratioY db 0
MouseX_Sum dw 160
MouseY_Sum dw 100
Cursor_attribute db 0F0h
Last_mask db 0
User_Event_Mask db 0 ; Changed: Cursor pos,left press, left rel, right press, right rel
Event_Handler_Addr dd 63620000h
ORG_AX dw 0
ORG_BX dw 0
ORG_CX dw 0
ORG_DX dw 0
ORG_DI dw 0
ORG_SI dw 0
ORG_ES dw 0
screenmask dw 0011111111111111b ; 0
dw 0001111111111111b ; 2
dw 0000111111111111b ; 4
dw 0000011111111111b ; 6
dw 0000001111111111b ; 8
dw 0000000111111111b ; 10
dw 0000000011111111b ; 12
dw 0000000001111111b ; 14
dw 0000000000111111b ; 16
dw 0000000000011111b ; 18
dw 0000000000001111b ; 20
dw 0000000011111111b ; 22
dw 0001000011111111b ; 24
dw 0111100001111111b ; 26
dw 1111100001111111b ; 28
dw 1111110001111111b ; 30
cursormask dw 0000000000000000b ; 0
dw 0100000000000000b ; 2
dw 0110000000000000b ; 4
dw 0111000000000000b ; 6
dw 0111100000000000b ; 8
dw 0111110000000000b ; 10
dw 0111111000000000b ; 12
dw 0111111100000000b ; 14
dw 0111111110000000b ; 16
dw 0111111111000000b ; 18
dw 0111111000000000b ; 20
dw 0100011000000000b ; 22
dw 0000011000000000b ; 24
dw 0000001100000000b ; 26
dw 0000001100000000b ; 28
dw 0000000000000000b ; 30
Int33_sub_index dw Fun_00 ; Reset/Query driver Presence
dw Fun_01 ; Display Pointer
dw Fun_02 ; Hide Pointer
dw Fun_03 ; Query Position & Buttons
dw Fun_04 ; Move Pointer
dw Fun_05 ; Query Button Pressed count
; BX = 0 left button
; 1 right button
; on return:
; BX = count of button presses (0-32767), set to zero after call
; CX = horizontal position at last press
; DX = vertical position at last press
; AX = status:
; |F-8|7|6|5|4|3|2|1|0| Button Status
; | | | | | | | | `---- left button (1 = pressed)
; | | | | | | | `----- right button (1 = pressed)
; `------------------- unused
dw Fun_06 ; Get Mouse Button Release Information
; BL=Button
; on return:
; BX = count of button releases (0-32767), set to zero after call
; CX = horizontal position at last release
; DX = vertical position at last release
; AX = status
dw Fun_07 ; Set Horizontal range
; CX = minimum H pos
; DX = maximum H pos
dw Fun_08 ; Set Vertical range
; CX = minimum V pos
; DX = maximum V pos
dw Fun_09 ; Set graphic pointer shape
; BX = horizontal hot spot (-16 to 16)
; CX = vertical hot spot (-16 to 16)
; ES:DX = pointer to screen and cursor masks (16 byte bitmap)
dw Fun_0A ; Set text pointer mask
dw Fun_0B ; Query last motion distance
dw Fun_0C ; Set Event Handler
dw no_fun ; Enable Light Pen Emulation
dw no_fun ; Disable Light Pen Emulation
dw Fun_0F ; Set Pointer Speed
; CX= Horizontal Ratio
; DX= Vertical Ratio
dw no_fun ; Set Exclusion Area
dw Fun_11 ; GET NUMBER OF BUTTONS (special PC1 MOUSE procedure)
dw no_fun
dw Fun_13 ; Set max for Speed Doubling
dw Fun_14 ; Exchange Event Handler
INT_08:
pusha
push ds
push cs ;variable segment!
pop ds
mov byte [Last_mask], 0
call read_M_delta_coord
cmp bl, 00h ; Value 00h or FFh = WAS MOVED!
jz go3
cmp byte [Cursor_Flag], 0 ; default -1 (FF) not visible
; visible=0
jnz go2
update_cur:
cli
mov dx, 3DDh
mov al, 60h+80h ;sistemiamo solo lo sprite per ora...
out dx, al
inc dx
mov ax, [MouseX_Sum]
shr ax, 1
add ax, [CenterX]
xchg al, ah
out dx,al
xchg al, ah
out dx,al
mov ax, [MouseY_Sum]
add ax, [CenterY]
xchg al, ah
out dx,al
xchg al, ah
out dx,al
sti
cmp bl, 0Fh ;me lo posso permettere perchè ho eliminato MOV mem,imm e CMP mem,imm -> CMP reg,imm
jz return_to_fun04 ;adjust_cursor was on-going
go2: or byte [Last_mask], 1 ; signal cursor movement to mask
push es
call Call_User ; there is X or Y movement!
pop es
go3: pop ds
popa
jmp far [cs:Old_INT08]
%macro CHECK_THRES 0 ;test for AX < [Max_speed_D2] in valore assoluto SENZA jump! (prima ce ne erano 2!!!)
; AX shifted if |AX| > [Max_speed_D2] - CX Corrupted - speed optimized
push AX
mov CX, AX
SHR CX, 0Fh
xor AX, CX
sub AX, CX
cmp ax, [Max_speed_D2] ;carry set if Below [Max_speed_D2]
cmc ;set if Higher of [Max_speed_D2]
xor cl, cl
rcl cl, 1 ;cl=1 if carry set, 0 otherwise
pop ax ;tiriamo fuori il valore originale
shl ax, cl
%endmacro
read_M_delta_coord: ; (BL) lo uso come "was moved!"
mov BL, 0 ; was moved = no
mov al, 10h ; load CTRC register
out 0D4h,al
in al, 0D5h
cmp al, 0
je rm2 ; non è cambiata la "X"
cbw ; Converts byte in AL to word Value in AX by extending sign of AL throughout register AH.
neg ax ; negative! la X è sepre negativa, non so perchè
dec BX
add [H_Mickey_Count], ax ;here the mickey are NOT doubled!
CHECK_THRES
mov CL, byte [shift_ratioX] ;shifting is better than IMUL/IDIV 50+34=84 Clock!!!
shl ax, cl
add ax, [MouseX_Sum]
call Verify_in_HRange
mov [MouseX_Sum], ax
rm2: mov al, 11h ; load CTRC register
out 0D4h,al
in al, 0D5h
cbw
cmp ax, 0
je rm4
dec BX ; was moved = sì più corto ancora: 1 solo byte
CHECK_THRES
rm3: add [V_Mickey_Count], ax ;here the mickey are NOT shifted
mov CL, byte [shift_ratioY] ;shifting is better than IMUL/IDIV 50+34=84 Clock!!!
shl ax, cl
add ax, [MouseY_Sum]
call Verify_in_VRange
mov [MouseY_Sum], ax
return_to_fun04: ;sì è pulcioso, si risparmia un'altro byte se è meno lontano di 127 byte!
rm4: ret
; NOTA: non uso pushf/popf perchè sono già salvate da INT09 procedure
INT_09bis: push ax
call Has_been_pressed_a_Mkey
or al, al
jnz pressed
pop ax
jmp far [cs:Old_INT09_MONK]
INT_09: push ax
or al, al
jz GoTo_OldInt
pressed: pusha
push es
push ds
push cs ;RIGHT SEGMENT FOR DATA
pop ds
;mov bx, cs
;mov ds, bx
;mov es, bx
mov ah, [KeyStatus]
test al, 4
jnz short loc_DE6
test al, 80h
jnz short loc_DE0
or ah, 2
jmp short loc_DF3
loc_DE0:
and ah, 1
jmp short loc_DF3
loc_DE6: test al, 80h
jnz short loc_DF0
or ah, 1
jmp short loc_DF3
loc_DF0: and ah, 2
loc_DF3: and ah, 3
mov [KeyStatus], ah
mov al, ah
call Update_keyCount
call Call_User
pop ds
pop es
popa
pop ax ;pre-interrupt AX preserved!
iret
; ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
GoTo_OldInt: pop ax
jmp far [cs:Old_INT09]
; ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ S U B R O U T I N E ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
;corrupt only AX!
Has_been_pressed_a_Mkey:
in al, 64h ; AT Keyboard controller 8042.
and al, 0D0h
jz short loc_1C2C
xor ax, ax
ret
loc_1C2C: in al, 60h ; AT Keyboard controller 8042.
mov ah, al
cli
mov al, 61h ; Ok, key processed!
out 20h, al ; Interrupt controller, 8259A.
sti
mov al, ah
no_fun: ret
no_user_fun:
retf
Update_keyCount: ;AL= xxxxxLxR
mov bx, [Button_Status]
mov byte [Button_Status], al
xor cx, cx ;azzeriamo CH CL - CH tiene i bit RRLL, CL il numero di shift da fare
xor al, bl
shr al, 1 ;tasto SX: Carry =1 se cambiato =0 se non cambiato rispetto al vecchio status
rcr ch, 1 ;inseriamo questo valore nel byte, al primo posto (+ significativo)
shr ah, 1 ; Carry =1 se Pressed =0 se released
rcl cl, 1 ; Qui CL diventa 1 se il tasto è pressed!
shr ch, cl ; Se pressed è il quarto bit da mettere a 1, quindi lo spingo ancora avanti tipo "01000000"
; finito con il tasto sinistro = CH="LL000000"
mov cl, 0
cmc ; Toggles (inverts) the Carry Flag
rcl cl, 1 ; Qui CL diventa 1 se il tasto è released!
shr ch, cl ; aggiungiamo uno zero se è released -> "0LL0000", altrimenti invariato
shr al, 1 ; tasto DX: Carry =1 se cambiato =0 se non cambiato rispetto al vecchio status
rcr ch, 1 ; lo aggiungiamo al solito a sx: adesso abbiamo: "RLL00000" o "RRLL0000"
xor cl, 1 ; Inverto CL: se era 0 diventa 1 e viceversa
shr ch, cl ; quindi aggiungiamo uno zero se è pressed -> "0RLL0000", altrimenti invariato
shr ch, 4 ;adesso abbiamo in CH i 4 bit 0000RRLL
mov dh, ch
mov dl, ch
shl dl, 1 ;DL è pronto per andare in [last_mask] '000RRLL0'
mov si, [MouseX_Sum]
mov di, [MouseY_Sum]
xor bx, bx
mov cl, 4 ;4 passaggi LB_Press, LB_Release, RB_Press, RB_Release
.next shr dh, 1
jc .updatePR
.cont add bx, LB_Count_releases-LB_Count_press
loop .next
mov byte [Last_mask], dl
ret
.updatePR inc word [LB_Count_press+bx]
mov word [LB_PosX_last_press+bx], si
mov word [LB_PosY_last_press+bx], di
jmp .cont
INT_33:
or ah, ah
jnz call_old33_if_exist
%endif
sti
call Call_Subfun
end_int33:
iret
call_old33_if_exist:
cmp word [cs:Old_INT33+2], 0
jz end_int33
jmp far [cs:Old_INT33]
%endif
Install_INT09_MONK:
cli
mov ax, 3509h
int 21h ; DOS - 2+ - GET INTERRUPT VECTOR
; AL = interrupt number
; Return: ES:BX = value of interrupt vector
mov word [Old_INT09_MONK], bx
mov word [Old_INT09_MONK+2], es
mov dx, INT_09bis ; Int 09 (BIS) Entry Point
mov ax, 2509h
int 21h ; DOS - SET INTERRUPT VECTOR
; DS:DX = new vector to be used for specified interrupt
sti
ret
;check for INT_09 hook!
Check_INT09_MONK:
xor ax, ax
mov es, ax
mov ax, cs
cmp word [ES:09h*4+2], ax ;check for int09 data segment
je allok
;SEMPLIFICO: se non è nel segmento la cambio altrimenti lascio stare!
;mov ax, 3509h
;int 21h ; DOS - 2+ - GET INTERRUPT VECTOR
; ; AL = interrupt number
; ; Return: ES:BX = value of interrupt vector
;mov ax, cs
;mov cx, es
;cmp ax, cx
;jne install_newint ;qualcuno (monkey?) ha cambiato l'int 09
;mov cx, INT_09
;cmp cx, bx
;je allok
;mov cx, INT_09bis
;cmp cx, bx
;je allok
install_newint: call Install_INT09_MONK
allok: ret
Reset_pointer_and_var:
xor ax, ax ;mov mem, ax è più veloce e occupa meno di mov mem,0
mov bx, 8 ;per i valori da 8
mov word [MouseX_Sum], 320
mov word [MouseY_Sum], 100
mov word [Hor_Ratio], bx
mov word [Vert_Ratio], bx
mov byte [Already_in_user], al
mov byte [User_Event_Mask], al
mov word [Event_Handler_Addr+2], cs
mov dx, no_user_fun
mov word [Event_Handler_Addr], dx
mov word [H_Mickey_Count], ax ; horizontal mickey count (-32768 to 32767)
mov word [V_Mickey_Count], ax
mov word [X_Mult_Ratio], bx
mov word [Y_Mult_Ratio], bx
mov byte [CenterX], 15
mov byte [CenterY], 15
mov byte [Max_speed_D2], 2
mov byte [Max_Speed_D], 35h
mov word [MIN_VRange], ax
mov word [MIN_HRange], ax
mov BYTE [shift_X_Pos], al
call Check_INT09_MONK
mov ah, 0Fh
int 10h ; - VIDEO - GET CURRENT VIDEO MODE
; Return: AH = number of columns on screen
; AL = current video mode
; BH = current active display page
mov word [MAX_VRange], 199
mov word [MAX_HRange], 639
cmp al, 06h
je cnt1
mov BYTE [shift_X_Pos], 1
cnt1: lea si, [screenmask]
call Copy_cursor_shape ; Copy cursor addressed by DS:SI
call TransMult
ret
Fun_00: mov [Cursor_Flag], byte 0
call Fun_02
call Reset_pointer_and_var
xor ax,ax
mov byte [User_Event_Mask], al ; Changed: Cursor pos,left press, left rel, right press, right rel
dec ax ;mov ax, 0FFFFh ;INSTALLED
mov [ORG_AX], ax
mov ax, 2 ;0FFFFh ;2 Buttons
mov [ORG_BX], ax
ret
; Display Pointer
Fun_01 cmp byte [Cursor_Flag], 0 ; default -1 (FF) not visible
; visible=0
jz end_fun_01 ; già visibile
inc byte [Cursor_Flag]
jnz end_fun_01
mov ah, byte [Cursor_attribute]
mov al, 68h+80h
out 0DDh,AX ;DD->AL DE->AH
jmp adjust_cur
end_fun_01: ret
; Hide Pointer
Fun_02 dec byte [Cursor_Flag]
;cmp byte [Cursor_Flag], 0FFh ; default -1 (FF) not visible
; visible=0
;jnz end_fun_02 ; always HIDE!
mov al, 68h+80h
mov ah, 0Fh ;cursor transparent
end_fun_02: ret
Fun_03: ;pushf ; out:
; CX = Horizontal (X) position
; DX = Vertical (Y) position
; BX = Button Status (bit 0-1=L-R)
mov ax, [Button_Status]
mov [ORG_BX], ax
mov [ORG_CX], ax
mov [ORG_DX], ax
;popf
ret
; Move Pointer
Fun_04: mov ax, dx
call Verify_in_VRange ; Verify if pointer in Vertical Range
; if not then move
mov bx, ax
mov ax, cx
call Verify_in_HRange ; Verify if pointer in Horizontal Range
; if not then move
mov [MouseY_Sum], bx
; visible=0
jnz endfun4
adjust_cur mov BL, 0Fh ;usede to call/ret on update_cursor ^^
call update_cur
endfun4:
ret
; 1 right button
; on return:
; AX = status:
Fun_05: cmp bx, 1
ja Fun05_end
jb Fun_05Out
mov bx, RB_Count_press-LB_Count_press ;0=SX o delta=DX
Fun_05Out: xor ax, ax
xchg ax, [LB_Count_press+BX] ;così azzero anche COUNT con un'unica istruzione, veloce!
mov [ORG_BX], ax
mov ax, [LB_PosX_last_press+BX]
mov [ORG_CX], ax
mov ax, [LB_PosY_last_press+BX]
mov [ORG_DX], ax
mov [ORG_AX], ax
Fun05_end: ret
; BL=Button
; on return:
; AX = status
Fun_06:
cmp bx, 1
ja Fun05_end
jb .phase2 ;se bx=0 don't add L/R offset
.phase2 add bx, LB_Count_releases-LB_Count_press
jmp Fun_05Out
Fun_07: call Invert ; Invert CX/DX if necessary (DX<CX)
;pushf
cli
mov [MIN_HRange], cx
mov [MAX_HRange], dx
; if not then move
;popf
jmp adjust_cur
Fun_08 call Invert ; Invert CX/DX if necessary (DX<CX)
;pushf
cli
mov [MIN_VRange], cx
mov [MAX_VRange], dx
; if not then move
;popf
jmp adjust_cur
Fun_09: cli
neg bx
add bx, 16
mov [CenterX], bx
neg cx
add cx, 16
mov [CenterY], cx
push ds
mov si, dx
mov ax, [ORG_ES]
mov ds, ax
pop es
push es
pop ds
sti
jmp adjust_cur ;è cambiato il centro!
;ret
Copy_cursor_shape:
mov dx, 0DDh ;sistemiamo lo sprite...
xor ax, ax
out dx, al
inc dx
cld
mov cx, 20h ;32 valori word (64 byte)
.copy_next:
lodsw ; Load Cursor value
cmp cx, 10h ; if first 32 byte
jbe .ok ; also slow down a little the procedure: too fast in a "0-wait-state" PC1!
not ax ; invert it -> also is some byte less (8 byte!)
.ok: xchg ah,al
out dx, al
xchg ah,al
out dx, al
loop .copy_next ; Load Values
ret
; ¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦ S U B R O U T I N E ¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦
; Normally Set text pointer mask
; but in this special driver set the graphics cursor color attribute
; BX = FF , then CX = AND/XOR attribute. F0 = white/black not trasparent.
; DX = 1 -> blink
Fun_0A: cmp bl, 0FFh
jnz endfun
mov byte [Cursor_attribute], cl
mov al, 64h+80h ;register 64h
out 0DDh, al
xchg al, dl
or al, 110b ;set mask/and/xor = ON
out 0DEh, al
jmp Fun_01
;endfun0A: ret
Fun_0B: ;pushf
cli
xor ax, ax ;così azzeriamo in un passaggio solo!
xchg ax, [H_Mickey_Count] ; horizontal mickey count (-32768 to 32767)
mov [ORG_CX], ax
xor ax, ax
xchg ax, [V_Mickey_Count] ; vertical mickey count (-32768 to 32767)
mov [ORG_DX], ax
;popf
endfun: ret
; Set Event Handler
Fun_0C: ;pushf
cli
mov dx, [ORG_ES]
mov word [Event_Handler_Addr+2], dx
and cl, 7Fh ; exclude high bit (7)
mov byte [User_Event_Mask], cl ; Changed: Cursor pos,left press, left rel, right press, right rel
;popf
sti
ret
;Fun_0D: ret
;Fun_0E: ret
; Set Pointer Speed
Fun_0F: ;cmp cx,0
;je EndFun10 ;una divisione per /0 avrebbe esiti funesti!
;cmp dx,0
;je EndFun10
;mov [Hor_Ratio], cx
;mov [Vert_Ratio], dx
xchg ax, cx ;se porto tutto su AX risparmio 1 byte ogni operazione!
cmp ax, word 0000h
je .skipHor ;una divisione per /0 avrebbe esiti funesti!
mov [Hor_Ratio], ax
.skipHor xchg ax, dx
cmp ax, word 0000h ;una divisione per /0 avrebbe esiti funesti!
je EndFun ;pulcioso, ma risparmio 1 byte
mov [Vert_Ratio], ax
jmp TransMult
;Fun_10: ret
; Get driver type
; return_ AX= 33h
Fun_11: mov ax, 33h ;Special PC1 mouse driver
mov [ORG_AX], ax
mov al, 2
mov [ORG_BX], ax ;number of buttons
EndFun: ret
;Fun_12: ret
Fun_13: xchg ax, dx
mov [Max_Speed_D], ax
add ax, 11h
mov bx, 23h
xor dx, dx
div bx
mov [Max_speed_D2], ax
ret
Fun_14: ;pushf
cli
mov ax, word [Event_Handler_Addr]
mov [ORG_DX], ax
mov dx, [ORG_ES]
mov ax, word [Event_Handler_Addr+2]
mov [ORG_ES], ax
xor ax, ax
mov al, byte [User_Event_Mask] ; Changed: Cursor pos,left press, left rel, right press, right rel
mov [ORG_CX], ax
and cl, 7Fh
sti
;popf
EndFun14: ret
;Fun_15: ret
;Fun_16: ret
;Fun_17: ret
;Fun_18: ret
;Fun_19: ret
; Transform multiplier in SHIFT-LEFT
; me ne sbatto dei risultati che hanno un rapporto Mult/Ratio < 1 anche perchè il mouse è già lento così di suo
; [shift_X_Pos] già considerato!
TransMult: mov al, byte [shift_X_Pos] ;parto da questo valore
mov byte [shift_ratioX], al
mov ax, [X_Mult_Ratio]
xor dx, dx
div word [Hor_Ratio]
.redo1: shr AX, 1
cmp ax, 0
je .ok1
inc byte [shift_ratioX]
jmp .redo1
.ok1: mov byte [shift_ratioY], 0
mov ax, [Y_Mult_Ratio]
xor dx, dx
div word [Vert_Ratio]
.redo2: shr AX, 1
cmp ax, 0
je EndFun14 ;.ok2 - pulcioso ma risparmio!
inc byte [shift_ratioY]
jmp .redo2
;.ok2: ret
; Set mouse sensivity
; BX = horizontal coordinates per pixel
; CX = vertical coordinates per pixel
; DX = double speed threshold
Fun_1A: shr bx, 2
mov [X_Mult_Ratio], bx
shr cx, 2
mov [Y_Mult_Ratio], cx
call TransMult
jmp Fun_13 ; Set max for Speed Doubling
;adjust_mult: mov bl, 0Ah
; div bl
; xor ah, ah
; cmp al, 0Ah
; jbe short loc_B9B
; mov al, 0Ah
;loc_B9B: mov bx, moltiplic
; ;add bx, ax
; ;mov al, [bx] ;qui uso XLAT = mov al, [BX+AL]
; XLAT
; ret
;moltiplic db 1, 2, 3, 4, 6, 8, 0Ah, 0Eh, 12h, 16h, 1Eh
; Query Mouse Sensivity
Fun_1B: ;mov ax, [Hor_CoordXPixel]
shl ax, 2
mov [ORG_BX], ax
;mov ax, [Ver_CoordXPixel]
shl ax, 2
mov [ORG_CX], ax
mov ax, [Max_Speed_D]
mov [ORG_DX], ax
ret
;Fun_1C: ret
;Fun_1D: mov [CRT_page_num], bx
; ret
;Fun_1E: mov ax, [CRT_page_num]
; mov [ORG_BX], ax
; ret
;Fun_1F: ret
;Fun_20: ret
;Fun_21: ret
;Fun_22: ret
; LANGUAGE = ITA!!! :)
Fun_23: mov word [ORG_BX], 08h
ret
; 24 - Get software version, mouse type and IRQ
; Out: [AX] = 24h/FFFFh (installed/error)
; [BX] (version)
; [CL] (IRQ #/0=PS/2)
; [CH] = 1=bus/2=serial/3=InPort/4=PS2/5=HP (mouse type)
; Use: driverversion
Fun_24: mov word [ORG_BX], driverversion
mov word [ORG_CX], 0309h ;inport, IRQ=09
ret
; Call INT 33 subfunction in AX
Call_Subfun: push bp
push ds
push cs ;right segment!
pop ds
mov [ORG_AX], ax
mov [ORG_BX], bx
mov [ORG_CX], cx
mov [ORG_DX], dx
mov [ORG_DI], di
mov [ORG_SI], si
mov [ORG_ES], es
push ds
pop es
cmp ax, 14h
ja short OtherFuns ; other functions!
push si
mov si, ax
shl si, 1
mov ax, [Int33_sub_index+si]
pop si
call_it: call ax
jmp short loc_6F5
; 2A - Get cursor hot spot
; Out: [AX] (cursor visibility counter)
; [BX] (hot spot X)
; [CX] (hot spot Y)
; [DX] = 1=bus/2=serial/3=InPort/4=PS2/5=HP (mouse type)
; cmp al, 2Ah
; jnz short Fun_4D
; mov ax, [Cursor_Flag]
; mov [ORG_AX], AX
; mov ax, 16
; sub ax, [CenterX]
; mov [ORG_BX], AX
; mov ax, 16
; sub ax, [CenterY]
; mov [ORG_CX], AX
; mov word [ORG_DX], 3 ;inport mouse
; jmp short loc_6F5
Fun_4D: ; Pointer to Microsoft Label!
mov word [ORG_DI], Copyright1983
mov [ORG_ES], cs
ret
Fun_6D: jnz short loc_6F5
mov [ORG_DI], word magicnumber ;word 204h
mov [ORG_ES], cs
ret
execute: shl bx,1
call [CS:other_address+bX]
jmp short loc_6F5
OtherFuns: mov bx, 4
more: cmp al, [other_num+bx]
jz execute
dec bx
jnz more
loc_6F5:
mov ax, [ORG_ES]
mov es, ax
mov si, [ORG_SI]
mov di, [ORG_DI]
mov dx, [ORG_DX]
mov cx, [ORG_CX]
mov bx, [ORG_BX]
mov ax, [ORG_AX]
pop ds
pop bp
ret
other_address: dw Fun_1A, Fun_1B, Fun_23, Fun_24, Fun_4D, Fun_6D
other_num db 1Ah, 1Bh, 23h, 24h, 4Dh, 6Dh
Call_User:
cmp byte [Already_in_user], 0FFh
jz endend
mov byte [Already_in_user], 0FFh
xor ax,ax
mov al, byte [Last_mask]
and al, byte [User_Event_Mask] ; Changed: Cursor pos,left press, left rel, right press, right rel
mov bp, Event_Handler_Addr ; Custom Event Handler
jz no_sub
call CALL_FUN_AT_BP ; call function (save all registers)
; @ BasePointer
no_sub: mov byte [Already_in_user], 0
endend: ret
; @ BasePointer
CALL_FUN_AT_BP:
mov cx, [MouseX_Sum]
mov dx, [MouseY_Sum]
mov si, word [H_Mickey_Count] ; horizontal mickey count (-32768 to 32767)
mov di, word [V_Mickey_Count] ; vertical mickey count (-32768 to 32767)
;pushf
sti
call far [cs:bp]
;popf
PUSH CS ;return to my DS segment
POP DS
ret
Invert: cmp cx, dx
jl short locret_D05
xchg cx, dx
locret_D05: ret
;Input: AX=Vertical Pos
; if not then move
; Corrupt AX, DX
Verify_in_VRange:
;push dx
mov dx, [CS:MIN_VRange]
cmp ax, dx
jl short .set
mov dx, [CS:MAX_VRange]
cmp ax, dx
jle short .skip
.set:
mov ax, dx
.skip: ;pop dx
ret
;Input: AX=Horizontal Pos
; if not then move
; Corrupt AX, DX
Verify_in_HRange:
;push dx
mov dx, [CS:MIN_HRange]
cmp ax, dx
jl short set2
mov dx, [CS:MAX_HRange]
cmp ax, dx
jle short skip3
set2:
mov ax, dx
skip3: ;pop dx
ret
;************** Constants / Costanti ****************************************
Copyright1983 db 'Copyright 1983 Microsoft ***'
magicnumber db 55h, 64h
; ========================== END OF RESIDENT PART =========================
notresident:
db '*** This is a PC1 mouse driver by Riminucci Simone (c) 2016, but some software expect here the upper string!'
welcome DB 'þ MOUSE-PC1 Driver ver. 0.97 - Simone Riminucci (C) 2016',0Dh,0Ah,'$'
already DB 'Û²²±±±°°°° Un driver Š gi… installato °°°°±±±²²Û',0Dh,0Ah,'$'
EGAVGA DB 'Û²²±±±°°°° EGA/VGA Patch installata (funz. avanzate disab.) °°°°±±±²²Û',0Dh,0Ah,'$'
ForceIn db 'F: Il driver sar… installato sopra uno esistente',0Dh,0Ah,'$'
SiamoSpiacenti db 'Non Š stato possibile installare il driver del mouse',0Dh,0Ah
db 'Questo mouse driver funziona solo su OLIVETTI PRODEST PC1. ',0Ah, 0Dh,'$'
aSpiacentiIlMou db 'Û²²±±±°°°° Attenzione: il mouse NON Š connesso. °°°°±±±²²Û',0Ah,0Dh,'$'
helpmsg db 0Ah,0Dh,"Parametri:",0Ah,0Dh
db 0Ah,0Dh
db "/I - Non verificare se su Olivetti Prodest PC1",0Ah,0Dh
db "/M - Mostra subito il cursore in DOS",0Ah,0Dh
db "/F - Forza l'installazione anche su driver esistente",0Ah,0Dh
db "/E - Forza l'installazione della Patch EGA/VGA",0Ah,0Dh
db "$"
Equipment_Addr dw 0A1h
start:
push cs
pop ds
lea dx, [welcome] ; "Benvenuti"...
mov ah, 9
int 21h ; DOS - PRINT STRING
call process_cmdline ; grab switches, etc
test byte [cmdlineflags], help
jnz display_help
test byte [cmdlineflags], nocheck
jnz skipcheck
call check_for_PC1
or ax, ax
jz not_PC1
skipcheck:
mov AX,0000h ;intallation check if already installed
int 33h
cmp AX,0FFFFh
%ifndef DEBUG
jne cont0
test byte [cmdlineflags], forceinst
jz terminate
lea dx, [ForceIn] ; ">Forced!"...
mov ah, 9
%endif
cont0:
cli
call set_mouse_keyb ; Set keyboard chip 8042
; to respond to mouse click -> scancode
; Left Button 77h
; Middle Button 78h
; Right Button 79h
or al, al
%ifndef DEBUG
jz short print_mouse_non_connesso
%endif
call Install_INT08
call Install_INT09
call Install_INT33
call reset_V6355D
test byte [cmdlineflags], showcurs
jz skipshow
call Fun_01
skipshow:
STI
terminate_but_stay_resident:
cont3:
mov ah, 51h ;Get application's PSP address
int 21h ;we get it in bx
mov es, bx
mov es, [es:2Ch] ;Get address of environment block.
mov ah, 49h ;DOS deallocate block call.
int 21h ;get rid of PSP!
mov dx, notresident ; only resident part will be saved
mov cl, 4
shr dx, cl ; paragraph to keep
inc dx ; 1 paragraph more... safer for roundings
MOV AX, 3100h ;
INT 21h ;stay resident and exit
terminate:
lea dx, [already] ; "Già installato!"...
mov ah, 9
error:
MOV AX, 4C01h ;AH 4C = Exit to DOS, ERRORLEVEL AL 01
INT 21h
print_mouse_non_connesso:
lea dx, [aSpiacentiIlMou] ; "Non connesso!"...
mov ah, 9
MOV AX, 4C02h ;AH 4C = Exit to DOS, ERRORLEVEL AL 02
INT 21h
reset_V6355D:
cli
;mov dx, 3DDh
;mov al, 65h+80h
;out dx, al
;inc dx
;mov al, 89h ;mouse enable
;out dx, al
push ds
mov bx, [Equipment_Addr]
mov ax, BIOS_DATA_SEG
mov ds, ax
mov al, [bx]
pop ds
test byte [cmdlineflags], forceEGA
jnz .force
test al, 1
jz .cont
.force and al, 0FEh ; azzera l'ultimo bit
;;;;mov [bx], al ; lo riscrivo indietro in modo che non venga più cambiato!?!?
or byte [cmdlineflags], forceEGA ; mi segno che era quello!
out 68h, al ; così "accende" lo schermo V6355D e il counter del mouse
in al, 0D1h
cmp al, 0FFh ; questo controllo è utile solo per computer non-pc1
jnz .wmsg
jz not_PC1
.wmsg lea dx, [EGAVGA] ; "EGA/VGA Patch installed"...
mov ah, 9
.cont mov dx, 3DDh
mov al, 64h+80h
out dx, al
inc dx
mov al, 6h ;mouse AND & XOR enable
out dx, al
sti
ret
check_for_PC1:
PC1_Equipment_Addr EQU 89h
PC1HD_Equipment_Addr EQU 0A1h
push bx
push ds
mov ax, 0F000h
mov ds, ax
mov bx, 0FFFDh ; penultimi due byte del BIOS
mov ax, [bx]
pop ds
mov bl, PC1HD_Equipment_Addr
cmp ax, 0FE44h ; PC1 - Floppy
jz short pc1dd
cmp ax, 0FE49h ; PC1 - Unknown
jz short loc_2B1C
cmp ax, 0FE4Ah ; PC1 - HD
jnz short loc_2B22
pc1dd: mov bl, PC1_Equipment_Addr
loc_2B1C:
mov ax, 0FFh
jmp short loc_2B25
loc_2B22:
mov ax, 0
loc_2B25:
mov [Equipment_Addr],bl
pop bx
ret
not_PC1:
lea dx, [SiamoSpiacenti] ; "Siamo spiacenti di non poter installare"...
mov ah, 9
; DS:DX -> string terminated by "$"
jmp error
Value_for_8042 db 12h, 77h, 78h, 79h, 1 ;valori dei tre tasti del mouse: 77h 78h 79h
set_mouse_keyb:
cli
mov al, 12h
push ax
mov dx, 64h
wait_8042:
in al, dx ; AT Keyboard controller 8042.
and al, 2
jnz short wait_8042
pop ax
out dx, al ; AT Keyboard controller 8042.
wait_8042f:
and al, 1
jz short wait_8042f
and al, 1
jnz short skip
push si
lea si, [Value_for_8042]
mov cx, 5
cld
load_next:
lodsb ; Load Value: 12h 77h 78h 79h 01
push ax
mov dx, 64h
wait_8042g:
and al, 2
jnz short wait_8042g
pop ax
mov dx, 60h
loop load_next ; Load Value: 12h 77h 78h 79h 01
mov ax, 0FFh
pop si
sti
ret
skip: xor ax, ax
sti
ret
;Procedure: ucase
;Purpose: Converts character in AL to uppercase.
;Input: AL=character
;Output: AL=uppercase character (if a-z)
; All other registers preserved. (flags too)
;Processing: test valid range (a-z), set to upper, exit
ucase:
pushf
cmp al,"a" ;if it's not a-z, skipit
jb noupper
cmp al,"z"
ja noupper
and al,5fh ;strip off a few bits to make it upper
noupper:
popf
ret
;##################### start cmd line interpret ####################
; command line flags
help EQU BIT0 ; help requested
nocheck EQU BIT1 ; don't check for PC1
showcurs EQU BIT2 ; show cursor at loading
forceinst EQU BIT3 ; forced install over an existing driver
forceEGA EQU BIT4 ; force EGA/VGA book
debug EQU BIT5 ; debug bit
koverride EQU BIT5 ; debug bit
writeprotect EQU BIT6 ; write protected bit
noint10 EQU BIT7 ; light INT10 hook (composit)
process_cmdline:
push ds
push bx
push si
mov ah, 51h
int 21h
mov ds, bx
mov cx, bx
mov si, 80h
mov bh, 0
mov bl, byte [si]
add si, bx
inc si
mov byte [si], NULL ;zero terminate
mov si, 81h
cmdlineloop:
mov ds,cx
lodsb ;Transfers string element addressed by DS:SI to the accumulator
push cs
pop ds
cmp al, " " ; found a space?
jz cmdlineloop
cmp al, NULL ; found end of line?
jz exitpc
cmp al, "-" ; found a flag?
jz checkflags
cmp al, "/" ; found a flag?
jz checkflags
; unknow skip but show help
or byte [cmdlineflags], help
jmp cmdlineloop
exitpc: pop si
pop bx
pop ds
ret
checkflags:
mov ds,cx
push cs
pop ds
cmp al, " " ; false flag
jz cmdlineloop
jz exitpc
cmp al, "-" ; found a double flag?
jz checkflags
cmp al, "/" ; found a double flag?
jz checkflags
; must be a flag
call ucase
cmp al, "?"
jz sethelp
cmp al, "H"
jz sethelp
cmp al, "I"
jz setignorenotPC1
cmp al, "M"
jz setshowcursor
cmp al, "F"
jz setforceinst
cmp al, "E"
jz setforceEGA
jmp cmdlineloop ; nothing we care about, continue
; could jump to help msg
sethelp:
jmp checkflags ; allows flags to be stacked
setignorenotPC1:
or byte [cmdlineflags], nocheck
setshowcursor:
or byte [cmdlineflags], showcurs
setforceinst:
or byte [cmdlineflags], forceinst
setforceEGA:
;##################### end cmd line interpret ####################
Install_INT08:
cli
mov ax, 3508h
mov word [Old_INT08], bx
mov word [Old_INT08+2], es
mov dx, INT_08 ; Int 08 Entry Point
mov ax, 2508h
sti
ret
Install_INT09:
cli
mov ax, 3509h
mov word [Old_INT09], bx
mov word [Old_INT09+2], es
mov dx, INT_09 ; Int 09 Entry Point
mov ax, 2509h
sti
ret
Install_INT33:
cli
push ds
xor ax, ax
mov ds, ax
mov si, 0CCh
mov bx, [si]
mov cx, [si+2]
pop ds
mov [Old_INT33], bx
mov [Old_INT33+2], cx
%endif
lea dx, [INT_33] ; Int33 Entry Point
mov al, 33h
mov ah, 25h ; DOS - SET INTERRUPT VECTOR
int 21h ; AL = interrupt number
ret ; DS:DX = new vector to be used for specified interrupt
display_help:
mov ah, 9
lea dx, [helpmsg] ; display help message
int 21h
exit mov ax, 4c02h ; end
int 21h
END:
