eight088
Hi everyone,
I recently picked up a 1040ste and it seemed to work perfectly fine when I got it. I have it hooked up to my 1084s monitor with a composite cable. While playing a game the computer crashed, and after power cycling the machine I was only greeted with a white screen. I've tried to do a little bit of trouble shooting by following the Atari STe field service manual, found here (page 26 of the 69.7mb file) and have found the CPU has halted (low signal on the HALT pin). The reset circuit is fine, I don't get any unusual activity on the BERR pin of the CPU (always high), but I do get something that doesn't seem right on the 68901 chip.
In the manual, it says that the 68901 should respond to an MFPCS with DTACK. I monitored these two lines (on the 68901) when I turned on the computer, and there is activity on the DTACK line briefly when first turned on, but the CS line is high the entire time.
Does this seem wrong or do you think I'm going about this the wrong way? This is my first real attempt at using an oscilloscope to troubleshoot a computer, so I am welcome to suggestions and any help I can get. In the screenshot I took (attached), the yellow line is the CS line, and the blue line is the DTACK.
I should also add I haven't been able to test the ROM chips as I don't think I have anything to test them with.
Thanks for any help
Thanks for any help
