amattera99
- Joined
- Jun 25, 2024
- Messages
- 18
If anyone is interested in new drive sleds for their BA-23, I modeled an original in Fusion360 and uploaded the STL to printables. https://www.printables.com/model/1101031-dec-ba-23-drive-sled
I dropped it into an STL Viewer. The answer is "yes" :-}.Hi - Does it have the latching lug?
As I said, I modeled it after a real BA-23 drive sled, when I got my PDP11/73, it had custom drive sleds that were counter sunk holes in random scrap plastic, I wanted to do it right and this was the best way possible. Stay tuned, up next is a sled custom fit for the MFM emulator available on PDP8onlineHi - Does it have the latching lug?
Robin
I used Fusion360, I took measurements with a set of digital calipersWhat did you use to model it? How did you make measurements?
can confirm. they areI think they are exactly the same thing..
I can make mounts for a 3.5", I don't currently own a ZuluSCSI yet, so I don't know exact dimensions/hole placements, but I've got plenty of junk SATA 3.5" doing nothing better. Only reason why I want to model the MFM emulator is because I own one and will be using one with my MicroPDP11/73Mounting points for a 3.5" drive and/or ZuluSCSI would be great!
