thunter0512
I have created this thread for discussions about possible chassis extensions for a PDP-8/L to avoid polluting other threads.
I'm not sure in practice how much the lack of front panel switches would be a liability. I find myself using the higher fields from the front panel quite rarely. The lack of lamps might be confusing, though.Yes, the missing IF/DF switches are an issue in both cases; something external to the 8/L chassis would need to be engineered. Are you suggesting that the Omnibus backplane could then host arbitrary peripherals or simply be a easier means to support RAM vie the re-implemented memory controller?
I have to admit that I'm not able to fully grasp what you were up to from those pictures.I've been working on a stackable module idea to plug in the expansion slots of the 8/L.
I was offered a BM8/L recently. The the deal was to swap it for my Mark 8, but that is not going to happen...
