JohnElliott
Are you able to open it up and see if there's a label on the keyboard microcontroller? The 3270PC keyboard MCU is part number 1385001; the AT keyboard MCU is part number 1503099.
Can you record the scancodes sent by the keyboard using software (before being "scrambled" by the keyboard controller)? I would like to check what the dca 3270 keyboard I have does as well...
If you download KB from http://www.seasip.info/DOS/ it allows you to display the scancodes received without translation from the keyboard controller. So if you can get your keyboard hooked up to a PC that has a PS/2 or AT keyboard port and runs DOS, you can see the scancodes it sends.
Could be that this keyboard sends separate press and release scan codes, so pressing the key gives "1c", releasing the key gives "f0 1c". In that case it's easy "f0" is a prefix for release.
