Thank You! If I understand correctly, when you reconnect internal LCD, it does not operate, just blinks when the external monitor is connected, while the external monitor operates perfectly. If you unplug at that moment the external monitor, will the internal LCD switch on? If that is a case, than after installation of your wire harness it will be very easy to use the book both with the internal and external monitors, just by plugging external monitor in? As soon as your wire harness is path through, it should be the case!
