Hi All,
I have a "vintage" 286 xt from Micro Main Computer Corp, called a Tiger-286 AXT Version 1.2 from (6/8/88) that I'm having a problem getting to finish the boot process.
It has a Modular Bios V3.0 (10/21/87) from Award Software.
When I turn it on the process tests each of the drives ok and then:
. checks interrupt controller # 1 Good,
. reveals system memory at 640,
. tests system memory Good,
. checks for unexplained interrupts and stuck nmi Good,
. Get, "keyboard error or no keyboard present."
. Press F1 key to continue.
I am using a newer keyboard (that works on my other computer) with a converter to work with the old 286. The converter is brand new.
I press the key and nothing happens. Any ideas? Thank you in advance for any help you may render.
Retread1
Retread1
