Booting a Kaypro10 without HD?
RizThomas
Surrey,BC,Canada
I have a Kaypro 10 which I acquired almost couples years back but will not boot fully due to what i think is a corrupted HD or disk controller. It comes up with system errors and even trying to format the Disk Drive was a total failure.
I just want to keep it up as a running unit, be able to boot up till I get to the command line or run a demo apps (Floppy?). I hoped to buy a FreHDD kit but somehow that too did not materialize.
Can I just disconnect the whole HDD /controller and just run from floppy?
Thanks
RizThomas
phogren
Morro Bay, CA
It should boot from a floppy. The A: drive will then be the floppy drive. If you have the Kaypro install disks you should be able to hit CONTROL C as it starts to boot and get to the prompt. I would check all the connections and the power supply before I gave up on the hard drive though.
deramp5113
Dallas, TX
I can run my Kaypro 10 from floppy without ever accessing the hard drive. The hard drive is still functional in my system, but I imagine it would work without it.
Mike
