intabits
So this ham-fisted clown was cleaning the front panel keypad of my 11/04, and not knowing how fragile they were, broke one of the buttons off.
The buttons are part of the frame, all being a single piece of plastic, but they are joined to the frame body only by a thin bridge at the top of the button, which flexes when the button is pressed.
(There seems to be no benefit to removing the screws, as the switch matrix pcb appears to be glued to the frame)
I've made an unintrusive repair by using a thin wad of paper to support the key to be flush with the frame like all the other keys, and joined it to the frame using a small piece of duct tape, then removed the paper.
(top-right button)
It appears to work well, but I expect that at some time the tape will lift, and a more permanent repair will be required.
I was thinking of finding some membrane (suggestions?) to replace the tape, that can be glued using an acetone/solvent adhesive that will "weld" into the plastic.
Does anyone here know of a permanent repair technique for this damage, or have any good suggestions?
(top-right button)
