I have a c64C which is showing a very similar fault to this:
The pictorial fault guide suggested that this fault could be caused by a faulty 7406 (U8) or 2 other 74LS14s - because I have the parts & wishfully thinking these may be relabelled on the 64c I replaced U23 (74LS14) & U22 (7406) - my tester showed both as being faulty but the issue persists.
I suspect U8 was probably amalgamated into U18 on the C64C (the Large Sharp IC). Am I on the right track?
This is a machine I had gifted to a friend, he has been using it without issue until this occurred after a power cycle - I'm not sure if anything got hot plugged.
