Replaced motherboard on 486 and am having issues with the cd-rom. Won't initiate on boot. Get error stating issue with board or cd-rom power. Ran soundcard setup as was having problems in game and it changed irq from 11 to 5, after that cd-rom doesn't initiate. Here are original files vs new. Tried adding the switches in new as seen below. Help would be greatly appreciated!
current autoexec.bat
SET SOUND=C:\SONIC
SET BLASTER=A220 I5 D1
C:\SONIC\MZTVOL.EXE
C:\WINDOWS\SMARTDRV.EXE /X
@ECHO OFF
PROMPT $p$g
PATH C:\WINDOWS;C:\DOS;C:\WP60
rem ******************* Mouse Setup ************************
PATH = C:\MOUSE;%PATH%
MOUSE CENHANCE
rem ************************************************** ******
SET TEMP=C:\DOS
LH C:\DOS\MSCDEX /D:MSCD001
C:\CLUTIL\CLMODE m5
old autoexec
SET SOUND=C:\SONIC
SET BLASTER=A220 I11 D1
C:\SONIC\MZTVOL.EXE
@ECHO OFF
PROMPT $p$g
MOUSE CENHANCE
SET TEMP=C:\DOS
C:\CLUTIL\CLMODE m5
current config... i added the switches to see if it would help
DEVICE=C:\SONIC\MZTINIT.SYS /A220 /I5 /D1 /P /CA340 /CI10 /V7
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\WINDOWS\HIMEM.SYS/testmem
ff
DOS=HIGH
FILES=30
DEVICE=C:\WINDOWS\IFSHLP.SYS
DEVICE=C:\DOS\CDMKE.SYS /D:MSCD001
STACKS=9,256
old config
DEVICE=C:\SONIC\MZTINIT.SYS /A220 /I11 /D1 /P /CA340 /CI10 /V7
ff
DOS=HIGH
FILES=30
STACKS=9,256
SET SOUND=C:\SONIC
C:\SONIC\MZTVOL.EXE
@ECHO OFF
PROMPT $p$g
MOUSE CENHANCE
SET TEMP=C:\DOS
C:\CLUTIL\CLMODE m5
old autoexec
SET SOUND=C:\SONIC
C:\SONIC\MZTVOL.EXE
@ECHO OFF
PROMPT $p$g
MOUSE CENHANCE
SET TEMP=C:\DOS
C:\CLUTIL\CLMODE m5
DOS=HIGH
FILES=30
STACKS=9,256
old config
DOS=HIGH
FILES=30
STACKS=9,256
