carlos12
I've been doing some tests on 640x200 CGA composite mode (which transforms on 160x200x16 colors). I've been using a program written by Michael Abrash and Dan Illowsky, published on their 1984 book Graphics for the IBM PC. I just added a few lines of code to test changing the foreground color in order to navigate all the color palettes.
While trying the 15 palettes, I found one that matched my graphical needs almost completely, using fore color 6. The problem es that on DosBox 0.74-3 it looks too good to be true. So I also tried on DosBox-X, 86Box and PcEm. Unfortunately, it only looks this good on DosBox 0.74, so I guess that it draws the composite colors wrong when not using the default set. Could someone confirm this is this way? I attached a capture of the same program running on DosBox 0.74 and DosBox-X.
The program I used to display all the palettes is this one:
100 REM Program to demonstrate color generation in
110 REM hi-res mode by artifacting.
120 REM Set screen to hi-res mode
130 SCREEN 2:KEY OFF:CLS
135 LET NCOLOR=1
140 REM Enable color burst so TV will display color
150 OUT &H3D8,26
154 REM Select foreground color
155 OUT &H3D9,NCOLOR
160 REM Label column that color numbers will go in
170 LOCATE 1,38:PRINT "COLOR #"
180 REM Draw using each of the 16 colors in turn
190 FOR I=0 TO 15
200 REM Set point at which to begin drawing colored area
210 PRESET (120,I*8+16)
220 REM Draw columns 100 to 250
230 FOR K=100 TO 250 STEP 4
240 REM Draw set of 4 pixels, producing one
250 REM artifacted colored pixel. Color is based
260 REM on the 4-bit pattern in I
270 FOR L=3 TO 0 STEP -1
280 REM Draw one column in white, if bit is 1, or
290 REM in black, if bit is 0
300 LINE -STEP(0,7),SGN(I AND 2^L):PRESET STEP(1,-7)
310 NEXT L
320 NEXT K
330 REM Label color number
340 LOCATE I+3,40:PRINT I
350 NEXT I
354 LOCATE 22,27:PRINT "FOREGROUND COLOR: ",NCOLOR
360 LOCATE 24,27:PRINT "PRESS ANY KEY TO CONTINUE";
370 A$=INKEY$:IF A$="" THEN 370
374 IF NCOLOR=16 THEN GOTO 380
375 NCOLOR = NCOLOR+1:OUT &H3D9,NCOLOR:GOTO 354
380 SCREEN 0,1:WIDTH 80:KEY ON 'Reset screen
390 END
