CGA/EGA/RGA/YUV To VGA Converter(NEW!)
sandy woo
China,Shenzhen
The RGB, CGA, EGA, HD to VGA Converter PCB board(GBS8220) is designed for application in Industry and Gaming. Used for the easy upgrade of old monitors to modern display screens. It accepts and converts input signal timings of CGA, EGA, High Definition 480–1080p/i and VGA for output at resolutions of slectable VGA, SVGA, XGA or HDTV.
It has a high compatibility with the majority of Video Systems as found in Industrial CNC machinery and Gaming cabinets. The output will support all CRT, LCD and PDP monitors. Now the retro-fit of older, superceded monitors is easy. The upgrade replacement monitors can also be better utilised for superior display of information and video using OSD options and colour adjustment pots.
Complete with two VGA D-sub outputs, available input connections are RGBS, RGBHV and Component RGB. Manual input selection by on-board push button controls and auto detection of the connected input signal timing allows for easy connection of the video source.
FEATURES:
Supports CGA / EGA / VGA / YCbCr / YPbPr signal inputs
Input Connection (selectable): RGBS- 5 pin, RGBHV- 8 pin, VGA- 15 pin, Component RGB– 3AV.
Output Connection: Dual VGA- 15 pin, Dual VGA- 12 pin.
Supports VGA Output : VGA (640x480), SVGA (800x600), XGA (1024x768), HDTV (1360x768)
Input Signal Auto Scan: CGA (14.5-16.5KHz) / EGA (23.5-25.5KHz) / VGA (30.5-32.5KHz)
Input Signal Auto Scan YCbCr / YPbPr: (480i, 576i, 720i, 1080i, 480p, 576p, 720p, 1080p)
English and Chinese On Screen Display menu.
Supports Output Resolution control, Position control & Zoom control.
Digital 24-bit A/D converter for true 16.7-million color conversion.
Supports all VGA monitors (CRT, LCD, PDP)
Supports Gaming: ICB CM99, CYE, Amatic, Jolly Joker, Cuty Line, Dyna X, Psikyo, Bigigo
Supports CNC Machinery: Drilling, EDM's, Lathes, Milling, Routers, Cutting, Welding, Grinding
Specifications:
Power: DC5V 2A +/- 0.5v (P7 or P9)
Input CGA signal: 14.5-16.5K Auto scan (P3 or P11 or P10)
Input EGA signal: 23.5-25.5K Auto scan (P3 or P11 or P10)
Input VGA signal: 30.5-32.5K Auto scan (P10 or P11)
Input YPbPr signal: 480p,576p,720p,1080p Auto scan (P2)
Input YCbCr signal: 480i,576i,720i,1080i Auto scan (P2)
Output VGA signal: VGA-640*480, SVGA-800*600, XGA-1024*768, HDTV-1360*768
Technical Support: Mr. Wu
E-mail:sandy@gonbes.com
TEL Phone:0086-755-82053232 FAX:0086-755-82053969
ADD:NO.4W Suotaike Building, Bagua 4 Road,Futian Shenzhen, Guangdong 518029 China
sandy woo
China,Shenzhen
The CGA TO VGA Converter is only suggest used in game machine. most of the inductrial Machine cannot use it.
if you want to use in the industrial named CNC monitor like
Fanuc
A61L-0001-0072
A61L-0001-0074
A61L-0001-0076
A61L-0001-0077
A61L-0001-0078
A61L-0001-0079
A61L-0001-0086
A61L-0001-0087
A61L-0001-0090
A61L-0001-0092
A61L-0001-0093
A61L-0001-0094
A61L-0001-0095
A61L-0001-0096
Mitsubishi
C-3240LP
C3470
C-5470NS
CDT14111B
CDT14148B
MDT1283B-2A
MDT1216
MDT947
MDT947B
MDT947B-1A
MDT947B-2B
MDT962B-1A
Siemens
6FC3988-7AF01
6FC4600-0AR04
6FC4600-0AR50
6FC5103-0AB01
QDM-9WD-110
QDM-9WD-120
QDM-9WD-121
SC-1200 SM0901
576744TA 576745TA
Hitachi
C14C-1472DF
C14C-1472D1F
C-5470YE
CD1472D1M
CD1472D1M-2
CDT14111B
CDT14111B-8A
TX1424AD
C14C-1472DFA
TX1425B
TX1450A
TX1450AE
Toshiba
D9CM-01A
D9MM-11A
D9MR-10A
D9MR-51B
D14CM-01A
D14CM-06A
D15CM-04A
D15CM-06A
GE
44A717111
44A719977
44A719978
44A719979
Matsushita
KF-M7099H
TR-9DD1B
TR-9DK1
TR-9DK1A
TR-9DK1B
TR-9DKYC
TR-9K1B
TX-901AB
TR-120S9C
TX-1204
TX-1204AC
TX-1208AA
TX-1404
TX-1404AB
TX-1424
TX-1424AB
TX-1424AD
TX-1425B
TX-1450AB
TX-1450ABA
TX-1450AB5
TX-1450AE special.
Mazak
C-3240
C-3470
C-5470
8DSP40
26S14O19L
CD1472D1M
CDT-14148B
MDT1283-B
MDT925PS
MDT962B
ME12-PDB
HM12-PDB
Heidenhain
BC110B
BC120
BE211
BE411
Tatung
CD14
CD14JBS
CD14JDS
Totoku
MDT947B-1A
MDT947B-2B
MDT947B-3A
MDT947B-3B
MDT1283B
Magnetek
1051091000
14531400102
14531400107
576744TA
576745TA
579417TA
etc.
for the replacement of above CNC CRT monitor, you can use our EGA/CGA/MDA/RGB/RGB SOG/RGBHV to VGA Converter (GBS8219)
Details: http://www.gonbes.com/en/Gonbes-GBS-8219.html
sandy woo
China,Shenzhen
More video converters from Gonbes
1) CGA/EGA/RGB TO VGA Converter(GBS8200) specially for arcade game machine use and some CNC machine use.
http://www.gonbes.com/en/Gonbes-GBS-8200.html
- Supports CGA/EGA/YUV signal input.
- Supports VGA output 640*480,800*600,1024*768,1360*768
- CGA/EGA signal auto scan(15K,24K,31K)
- YUV signal auto scan(480i,576i,720i,1080i,480p,576p,720p,1080p)
- Chinese and English OSD.
- Supports position control & zoom control.
- True digital 24-bit A/D converter for true 16.7-million color conversion.
- Supports all VGA monitor (CRT、LCD、PDP、PROJECT……)
2) CGA/EGA/RGB TO 2VGA Converter(GBS8220) specially for arcade game machine use and some CNC machine use.
http://www.gonbes.com/en/Gonbes-GBS-8220.html
3) EGA/CGA/MDA/RGB/RGB SOG/RGB Sync/RGB HV To xVGA Converter(GBS8219) for industrial mornitor replacement.
- Support BNC, 9pin、3pin、6pin、14pin、20pin、25pin input
- Support input singals:MDA、CGA、EGA、RGB、RGB Sog、RGBSync、RGBHV、YPbPr
- Input Horizontal Frequency Rate 12kHz to 40kHz automatically recognized.
- Support Interlaced Scanning and Line by Line Scanning.
- Support Vertical Resolution from line200 to line 600 automatically recognized.
- Support variable Horizontal Resolution automatically recognized。
- Support RGBHV (separate sync) ,RGBS (composite sync), automatically recognized
- Output resolution: 800*600/60Hz standard VGA or custom-resolution.
4) YUV/VGA TO CGA CONVERTER(GBS-8150) specially for game use.
Details: http://www.gonbes.com/en/Gonbes-GBS-8150.html
- Supports YUV/VGA signal input.
- Supports VGA input 640*480,800*600,1024*768@60Hz
- YPBPR signal auto scan(480i ,720i,1080i,480p,720p,1080p)
- CGA output supports all CGA game monitor.
5) Vga to Cga Pal Ntsc Converter(GBS8100)
details: http://www.gonbes.com/en/Gonbes-GBS-8100.html
♦ Supports VGA/SVGA/XGA/SXGA(640*480,800*600,1024*768,1280*1024) signal input.
♦ Supports VGA output by pass.
♦ CGA signal output(15K).
♦ Video/S-Video output.
♦ Supports NTSC & PAL.
♦ Supports position control & zoom control.
♦ True digital 24-bit A/D converter for true 16.7-million color conversion.
♦ English OSD Adjust menu.
6) AV Video S-video to Vga Converter(AV128)
details: http://www.gonbes.com/en/Gonbes-AV-128.html
- Supported conversion of video signal formats: from CVBS or S-VIDEO signal into frequency multiplication processed high-resolution VGA signal.
- Multiple input signal formats are supported:CVBS, S-VIDEO and VGA. automatic identification of the two color systems i.e. PAL and NTSC is supported.
- Supported output resolutions: 800*600, 1024*768
- Image freese
- Adjustable brightness, contrast, color saturation and hue
- Current working status can be saved on accidental power-off
- Remote control supported(remote controller optional)
- Caption prompts fuction for all operation and status
- Dimensions: 110*62*25 mm
7) PC TO HDTV Extender, VGA+USB TO VGA+R/L Audo(GBS125) specially for home entertainment
Details: http://www.gonbes.com/en/Gonbes-GBS-125.html
- Superior digital high-definition audio and video transmission performance
Video
  Maximum resolution 1920x1080
Supporting format VGA,SVGA,XGA,SXGA,UXGA,480p,576p,720p, 1080i,1080p
Video interface D-Sub15 VGA
Audio  Supporting format 5.1/7.1 sound channel Dolby、DTS,2 sound channel stereo
Audio interface 3.5mm stereo earphone interface,SPDIFOptic fiber interface,RCA Audio interface
USB interface Support all equipment which fit USB2.0 full-speed/low-speed norm
Transmission range CAT-5、CAT-6 standard cable,the farthest range is 40m.
- supports all high-definition display devices with VGA-IN port, like: - LCD TV, plasma, rear projection TV - HD projectors, HD demo - other display devices supported VGA input, etc.
- supports 3 kinds of audio amplifier outputs:
(1) 3.5mm stereo
(2) optical audio
(3) RCA Audio
- supports a variety of USB2.0 peripherals, such as - wireless controller, wireless keyboard and mouse - dance mat, steering wheel, bolt game guns - other kinds of USB2.0 peripherals, etc.
8) Plug/Play USB to VGA Adaptor(GBS201) used to extend/mirror your pc display
Details: http://www.gonbes.com/en/Gonbes-GBS-201.html
- Supported additional display modes: 1. Main display, 2. Extending display 3. Mirror
- Directly connect to PC host with USB2.0 cable, easy to use, portable size,
- supported up to 8 attached displays to mirror or extend your PC working screen district, no need additional image card.
- Share with high definition or wide screen solution, 1280*1024/1400*1050 at 32 bit color( MAX resolution: 1600*1280 at 32 bit color)
- Supported up to 8 displays to work at the same time
- Supported KVMP'S and USB HUB
9) VGA TO AV Video S-video Converter(AV-3500) specially for home entertainment
Details: http://www.gonbes.com/en/Gonbes-AV-3500.html
-Supports Composite VIDEO,S-VIDEO,RGB
-Power from PS/2 or USB port
-On Screen Display(OSD) operation status, zoom, size
-Independent horizontal size and vertical size adjustment
-Pure hardware design, just Plug&Play no software or driver requirement, compatible with any operation sysem
-Switch able NTSC, NTSC-EIAJ(for Japan), PAL, PAL-M, PAL-N, PAL-combination
-N -Supports Position contral, ZOOM&MENU button -MENU button supports HSIZE, VSIZE, BRIGHTNESS, CONTRAST, SATURATION, HUE, SHARPNESS and OSD
-BACKGROUND color adjustment
-Simultaneous display on VGA monitor and TV -24 bit, true color digitizer
10) Wireless HDMI Transmitter and Receiver or Wireless HDMI Extender(GBS330)
Details: http://www.gonbes.com/en/Gonbes-GBS-330 v1.1.html
11) VGA+ R/L TO HDMI Converter (GBS01)
Details: http://www.gonbes.com/en/Gonbes-GBS01.html
12) DVI+SPDIF TO HDMI Converter(GBS02)
Details: http://www.gonbes.com/en/Gonbes-GBS02.html
13) YPbPr+SPDIF TO HDMI Converter(GBS03)
Details: http://www.gonbes.com/en/Gonbes-GBS03.html
14) HDMI TO Ypbpr/VGA Converter(GBS04)
Details: http://www.gonbes.com/en/Gonbes-GBS04.html
15) Ypbpr to HDMI Converter (GBS05)
Details: http://www.gonbes.com/en/Gonbes-GBS05.html
16) MINI 2x1 HDMI Switcher(GBS201M)
Details: http://www.gonbes.com/en/Gonbes-GBS201M.html
17) Mini 3x1 HDMI Switcher(GBS301M)
Details: http://www.gonbes.com/en/Gonbes-GBS301M.html
18) 3x1 HDMI Switcher(GBS301)
Details: http://www.gonbes.com/en/Gonbes-GBS301.html
19) 4x1 HDMI Switcher(GBS401)
Details: http://www.gonbes.com/en/Gonbes-GBS401.html
20) 5x1 HDMI Switcher(GBS501)
Details: http://www.gonbes.com/en/Gonbes-GBS501.html
21) MINI 1x2 HDMI Splitter(GBS102M)
Details: http://www.gonbes.com/en/Gonbes-GBS102M.html
22) 1x4 HDMI Splitter(GBS104)
Details: http://www.gonbes.com/en/Gonbes-GBS104.html
23) 1x8 HDMI Splitter(GBS108)
Details: http://www.gonbes.com/en/Gonbes-GBS108.html
24) 1x16 HDMI Splitter(GBS116)
Details: http://www.gonbes.com/en/Gonbes-GBS116.html
25) 4x2 HDMI Matrix(GBS0402)
Details: http://www.gonbes.com/en/Gonbes-GBS0402.html
26) 4x2 HIFI HDMI matrix(GBS0402HiFi)
Details: http://www.gonbes.com/en/Gonbes-GBS0402HIFI.html
27) 4x4 HDMI matrix(GBS0404)
Details: http://www.gonbes.com/en/Gonbes-GBS0404.html
gerrydoire
I have a GBS 8219, I couldn't get it to work very well with a CGA Video Card.
