sandy woo
The RGB, CGA, EGA, HD to VGA Converter PCB board(GBS8220) is designed for application in Industry and Gaming. Used for the easy upgrade of old monitors to modern display screens. It accepts and converts input signal timings of CGA, EGA, High Definition 480–1080p/i and VGA for output at resolutions of slectable VGA, SVGA, XGA or HDTV.
It has a high compatibility with the majority of Video Systems as found in Industrial CNC machinery and Gaming cabinets. The output will support all CRT, LCD and PDP monitors. Now the retro-fit of older, superceded monitors is easy. The upgrade replacement monitors can also be better utilised for superior display of information and video using OSD options and colour adjustment pots.
Complete with two VGA D-sub outputs, available input connections are RGBS, RGBHV and Component RGB. Manual input selection by on-board push button controls and auto detection of the connected input signal timing allows for easy connection of the video source.
FEATURES:
Supports CGA / EGA / VGA / YCbCr / YPbPr signal inputs
Input Connection (selectable): RGBS- 5 pin, RGBHV- 8 pin, VGA- 15 pin, Component RGB– 3AV.
Output Connection: Dual VGA- 15 pin, Dual VGA- 12 pin.
Supports VGA Output : VGA (640x480), SVGA (800x600), XGA (1024x768), HDTV (1360x768)
Input Signal Auto Scan: CGA (14.5-16.5KHz) / EGA (23.5-25.5KHz) / VGA (30.5-32.5KHz)
Input Signal Auto Scan YCbCr / YPbPr: (480i, 576i, 720i, 1080i, 480p, 576p, 720p, 1080p)
English and Chinese On Screen Display menu.
Supports Output Resolution control, Position control & Zoom control.
Digital 24-bit A/D converter for true 16.7-million color conversion.
Supports all VGA monitors (CRT, LCD, PDP)
Supports Gaming: ICB CM99, CYE, Amatic, Jolly Joker, Cuty Line, Dyna X, Psikyo, Bigigo
Supports CNC Machinery: Drilling, EDM's, Lathes, Milling, Routers, Cutting, Welding, Grinding
Specifications:
Power: DC5V 2A +/- 0.5v (P7 or P9)
Input CGA signal: 14.5-16.5K Auto scan (P3 or P11 or P10)
Input EGA signal: 23.5-25.5K Auto scan (P3 or P11 or P10)
Input VGA signal: 30.5-32.5K Auto scan (P10 or P11)
Input YPbPr signal: 480p,576p,720p,1080p Auto scan (P2)
Input YCbCr signal: 480i,576i,720i,1080i Auto scan (P2)
Output VGA signal: VGA-640*480, SVGA-800*600, XGA-1024*768, HDTV-1360*768
Technical Support: Mr. Wu
E-mail:sandy@gonbes.com
TEL Phone:0086-755-82053232 FAX:0086-755-82053969
ADD:NO.4W Suotaike Building, Bagua 4 Road,Futian Shenzhen, Guangdong 518029 China
FEATURES:
Specifications:
