I have a Commodore 128 that I stored for a couple of years. It was completely working before storing it. However, after taking it from storage it wasn't working. Initial symptoms were that it was completely dead. C128 mode gave only a "garbage" screen, albeit with the correct green border and grey background. Don't remember if pressing the Commodore key made a difference. However, using the C64 "dead test" pointed me to a failed U38. I replaced and C64 mode started working fine. All memory tests run fine. The C64 diagnostics 58620++ now give an almost perfect bill of health:
I've tried exchanging both 6526, but it reports the same. Regardless of what diagnostics says, C64 BASIC reports 38911 bytes free, so that looks fine.
However, C128 mode gives a blank screen, green border and grey background. Sometimes, either on power on or when pressing reset, I get this:
Or just random characters, but always with the correct colors. So it's very inconsistent in C128 mode. However, pressing the Commodore key correctly goes to C64 mode and everything works fine there.
I've tried running C128 Diagnostics 785260 and 789010JB, but the behavior is the same as with no cart.
Assuming I had bad high RAM, I exchanged lines GCAS0 and GCAS1 at R29 and R30. C64 diagnostics gave no memory errors, so I guess the high RAM is fine. However, this made no difference for C128 either. I also dumped the ROMs (all tested good compared to the corresponding P/N) and made sure they were in the correct place as per the service manual.
At this point I'm really out of ideas. I've obviously checked for any physical problems and no chip is significantly warmer than usual (i.e. nothing is burning). All voltages from the PS are fine, both in voltage and ripple (tested with the original PS and a modern recreation). Any suggestions would be greatly appreciated.
