GanjaTron
- Joined
- Jan 11, 2007
- Messages
- 201
Hi everyone, hope you all got the year off to a good start.
I have a CBM 8032 which has been in storage in my basement for aeons, along its 8050 dual floppy. I decided to finally check it out over the Xmas break as I ran into issues with the Big Bad Blue Mallory 27000 µF filter cap in my 2001, and I figured I should check the caps in my other PETs and floppies before placing an order for spares -- shipping to Europe is insane these days!
I never tried the 8050 before, but I do have a 4040 on my CBM 3032 which works without issues, so I had high hopes. The 8050 passes initial powerup with a green status LED, so I figure the digital board is ok, and I initially (and naively) expected no further problems. Haha.
The 8050 has DOS 2.5 in ROM and uses Micropolis 1006 drives. TBH not the best mechs I've seen, and I found the "tethered" setup with drive 1 dangling from drive 0's analogue board via very short cables to be a major pain when adjusting and troubleshooting.
Since I have no preformatted disks, I tried to format a spare DS/DD disk using the BASIC 4.0 "header" command. Both drives bump with a loud jarring noise and give up after a few seconds, but the status LED remains green. BASIC returns a "bad disk" error, but when I print ds$ I get "21,read error". Is the drive checking the formatted tracks on the fly?
Things I tried so far:
Many thanks and have a good weekend,
--Roland
- The 5V and 12V supply voltages and ripple are within spec
- I checked the disks mechanically, and found that drive 1 has major resistance on the stepper lead screw, and it makes a rumbling or "groaning" sound when seeking. The grease on the lead screw wasn't really hard but gunky, so I cleaned and relubed that on both drives, but there's still more resistance on drive 1, even after I ran a drop of oil down the stepper motor shaft. At this point I don't know whether it's the motor itself or the head carriage, and I'm hesitant to dismantle the thing as I'll then probably have to realign the drive -- without any reference disks.
- Lastly, I checked the spindle motor using the strobe method on both drives; they were basically spot on.
- The belts are a tad sloppy, but not to the point where they lose grip. That said, I'm not ruling out some slip. I suppose this could be checked via the indexing pulse period.
--Roland
