GiGaBiTe
with a G4 upgrade card.
The Beige G3 has a socketed CPU and most if not all upgrades for it are also socketed parts.
But I'd not recommend tossing a G4 upgrade in it. The Beige G3 officially only supports a 66 MHz bus speed which really slows down the extreme few G4 upgrades that support the native 100 MHz G4 bus. Most G3 to G4 upgrades are limited to 66 MHz bus speeds because of a bug in the Motorola chipset present on B&W G3s (I have a 733 MHz Sonnettech G4 upgrade and know all about it.)
The other issue is that the G4 doesn't offer more value for the majority of users. It only adds an Altivec unit which would only help in media encoding and some of the very last MacOS X PowerPC applications.
Here's a chart of how to use the jumper block on the Beige G3 if you want to change the clocks:
http://www.wmld.com/tech/jumperchart2.html
You can try overclocking your G3 if you want to get some extra speed. Generally they're pretty intolerant to overclocking, but you can usually get at least one multiplier up and sometimes two for a minor boost. I managed to get my 266 to 300 without much effort. 333 was a bit unstable unless I put a fan on the heatsink so that's as high as I wanted to push it.
