wulp
I just got 2 Compaq Armada 7000, with a failing harddisk. Reading around on the internet, I found that, on that system, the first partition contained the files needed to go to the bios (??).
So, I can startup from a diskette with DOS 6.22 on it, but FDISK isn't able to find the HDD. In the 10000 Softpaqs you find on the internet, I found a utility with 'Diagnostics' (SP10975 and others), but I'm unable to find the diskette (or sp) that I need to SETUP the machines.
Does someone know where to download it or witch number the SETUP sp has??
Thanks!
Thanks!
