Hi-
your problem is ... not a problem. Just rip out a floppy drive from any junk 'puter, and either replace your original drive with it, or plug it in the second connection on the floppy cable - it will automatically be configured as the second floppy drive (B
Some older ribbon cables don't have an index key, so make sure you plug the cable in the correct way, with the red (#1) edge closest to the power connector. If you plug the cable in upside - down, no worries - no damage done, but you'll see the drive light stay on & never go out. Just flip the cable upside-down.
You may not have the correct power cable on your PS, so you can either (1) buy an adapter (should be no more than $5), or (2) rip out one from a junk computer & wire it up.
You'll have top boot up into your bios configuration, and set up your new drive as 1.4 (you'll be offered a bunch of options). I'd set it up as the primary (A
dive, if I wanted to use it as a boot drive.
Also, if you want the install to look sexy, there are mounting adapters available (with face plate & all), which turn a full size bay into a 3.5 bay.
Have fun, you're unlikely to run into any problems, but, if you do - post again.
-dim
