Non working Portable III. When power is applied, PSU cycles, trying to start. I pulled the unit apart, and the PSU will run with no load, but clicks. If I slow down the fan, the unit resumes the cycling. Unless there's a way to fix the PSU, I think I need a replacement, but not sure if those are available, or if it's better to sell as a parts unit for someone else to finish a machine (I can't validate the screen until I can get it booted, nor the motherboard. Looks like it has a HDD in it, but can't see size (20 or 40). Case looks pretty good, tho, with a few cracks at the corners. KB cable is rotted, but KB otherwise in good shape.
Anyone have ideas on how I should proceed?
Jim
Jim
