Sorry to double-post, but the thread needs to be bumped if I'm posting new info after that long. If I'm wrong, then please edit the posts together and forgive me.
I transplanted the CPU, RAM, and HDD from my Presario 425 into my Prolinea Net/1 (same device, slightly newer chipset model, network card instead of modem). It pagefaults on running Quake. I tried taking the network card out physically, thinking perhaps it was a conflict of some kind, but that changed nothing. Since the software is identical (transplanted HDD), the RAM is identical, and the CPU is identical (and the jumper settings were made identical), the only variable left is the slightly newer chipset. The 425 uses VLSI 9336 chips, the Net/1 uses VLSI 9340 chips. I was hoping it might be a little faster at Quake, and wanted to see - ended up just learning that Quake didn't run right on that box. Thought I'd share my findings - if you intend to run Quake you may want to steer away from the Net/1, unless you think it was something other than chipset compatibility, the cause I arrived at.
According to this picture set of a Presario 433 and it's motherboard, it uses yet another, even newer, chipset than either of the machines I have - a 9406 on the big chip, and.. what looks like a mismatched 9402 on the smaller chip.
(It's possible that he blocked hotlinking so that you can't view the image if you didn't come from his page. It works for me, and that's likely because I went to his page and saw it there first. I'll just remove the first link..)
http://eintr.net/systems/compaq/presario433/index.html (Check the motherboard pictures)
Indeed, I am very obsessed with these boxen.
