Conventional Memories
Hi, I recently picked up a Compass 1101 but I don't have a floppy drive (yet), After a good cleanup and replacing the RTC battery and some RIFA caps the Compass works great.
Now, I was hoping there would be a way of transferring files to and from its bubble memory via serial or something, I know this can be done from DOS but at the moment only GRiD OS is installed.
I have already made a serial adapter from the special DE-19 connector to a more standard DB-25 but I'm not familiar enough with GRiD OS to know if serial transfers are possible between machines.
Thanks
Thanks
