T-R-A
MEMMAKER did ask about Windows 3.1, but I don't know what it did regarding that. I wish I did, because I just don't like knowledge of my own vintage computer's setup being obscured/taken away from me, after I've spent months setting up everything myself so that I know what is what and where it is.
You're being a little paranoid about what it (or any memory-manager) does. It's only probing higher memory (above 640K) that isn't being utilized for anything significant to relocate other things to it. A lot of space between the 640K to 1MB section is wasted in an "unoptimized" system. Only issue I've ever had with it was some older VGA drivers for Win3.1 (easily solved). And as for all the other config.xxx and autoexec.xxx files you've got...once you determine your system is fine, get rid of them. They're just sitting there eating up HDD space---and on small drives, that's always a concern. If you're running a slower system, run a defragmentation utility after everything checks out and you've deleted files you don't need... especially if you're not using a permanent swapfile for Windows.
