COPY.COM for 8" disks
Ah...yes, that could be the problem.
My DJ-2D board is set for the standard E000H address.
I'll see what I can do. Thanks for the insight.
Phil
Yep, that did the trick. Works great.
Did a down and dirty disassemble, then in a hex editor I manually changed the 'CD xx F8' calls to 'CD xx E0', and used the disassembled code just for cross reference.
I then loaded it onto my SOL via serials, and saved it under CP/M.
Works like a charm (Although I haven't tried it on those IMSAI disks).
Much thanks.
I've attached the altered .COM file for DJ-2D cards at E000h.
View attachment djcopy_E000h.zip
Philip
Much thanks.
Philip
I'm glad that worked. That program was apparently written by the gentleman who owned the IMSAI before me. He also made changes to the BIOS to add a 1024byte x 9 sector format to extend diskette capacity.
Just a quick follow up.
Seems this isn't copying all the data correctly. After a copy, the resultant disk books to CP/M with no issues, but many (all?) of the programs don't load and are somehow corrupt. Not sure why, but will try to find time to look into this further.
Phil
