I just acquired a old piece of test equipment from the 1990's. It is called a Protech PL5000 and it was made to test circuit boards and components in-circuit. It has sat on a shelf for the past twenty years. It runs on a 286 and has a ST251-1 in it. I would like to update the drive to something newer so that I have more features and access and longevity.
How do I get all of the info off of the drive? The Protech only has a 5.25 floppy and I have no discs at the moment. Is there a way to plug this into a newer computer that also has an IDE drive and windows and I can just drag and drop the files over? Is there an adapter that can go from this to IDE? Or any other way to get the info off of it?
And, What is best drive and controller to put into this 286? Can I do a newer IDE drive and will anyone work with a IDE controller?
Last question.
I would like to maybe update the 286 into something newer. This is one of the industrial kind of machines with the real long cards and ten or more back planes. I guess I will need a motherboard that has a large number of ISA slots 8 and 16bit. What is the best fit for something this old as far not being too fast but being compatible so that the test cards work. Pentium OK, 486? I am not sure what is made and what is not too expensive.
Thanks for the help,
Russ
Last question.
Russ
