I got a Commodore 64c set up and running Ivory BBS software. I decided to put it online so that people could see what Ivory is like. I'm calling the BBS "Cottonwood II", and you can access it at the same address as my main BBS, but at port 6400 instead of 23. So... From most terminals, you'd use the following address:
cottonwood.servebbs.com:6400
Or, with CGTERM, just replace the colon with a space:
cottonwood.servebbs.com 6400
A couple notes for those who are unfamiliar with Ivory BBS... First, when you connect, tap return/enter once to complete the connection. Then, the BBS should ask you to press "SHIFT-@" for graphics mode. This method of graphics terminal detection was used because Commodore computers were the only ones that were able to transmit this particular key combination (most other computers have "@" above the number "2", so you can't shift a shifted charachter). With CGTERM, the "@" key is mapped to "[", to the right of the letter "P", so you'll need to press "SHIFT-[" when it asks you to press "SHIFT-@". Of course, if you're calling with a non-Commodore graphic terminal, just press anything and you'll enter in ASCII mode. Finally, the first time you call, it'll ask if you're a member of the BBS. Answer no, then it'll ask for your name or user #. Since you don't have a user # yet, just type the handle you'd like to use. When you get to the main menu, press "A" to fill out an application for membership, and as soon as I validate your new account, you'll have access to the Sub-Boards (message area) and file transfer sections. I normally validate new accounts within 24 hours. If you'd like me to send you an e-mail letting you know when your account has been validated, just leave me a feedback message before you logoff and let me know what your Internet e-mail address is.
Any questions? Just ask!
-Andrew
-Andrew
