CP/M 86 - Command line Rebooting?
natcha
I have installed CPM-86 on Flash Card in an Omnibook 600C. I have a MSDOS partition and a CP/M partition on the hard drive. I would like an easy way to toggle between the two systems. On the MSDOS side, I have created a CPM.BAT Batch file that has the following commands and it work great:
setboot 4
reboot
On the CP/M side, I have a SETBOOT.CMD that lets me toggle the boot partition.
What's missing is a REBOOT.CMD command - if I had that then I could create a single command to boot back to msdos.
I've searched the web, but no luck. Soes anyone have any suggestions? I guess I could do an assemble program that would do a reboot - but I'm not much good with assembly.
Thanks,
Bill
Smithville, NJ
Untested, but try assembling this:
        mov     cl, 0Dh
        int     0E0h
        db      0EAh      ;Far jump to FFFF:0000.
        dw      00h
        dw      0FFFFh
        end
(To cross-assemble under DOS:)
RASM86 reboot
LINKCMD reboot
John,
I have Turbo Pascal installed on the CP/M-86 - I'll try your code as an in-line routine and see what happens.
Thanks,
Bill
Smithville, NJ
