regarding the membrane keyboards… one trick I stumbled upon totally by accident, is worth trying before you toss it in the scrap pile….
I was using hydrogen peroxide to retrobrite the case of a non-working LK201 keyboard. Since it was non-working I left the entire keyboard together (for the weight) and submerged it. After 4 or 5 hours in the sun and allowing it to dry for a few hours, I plugged it in and it worked!
I poked around a bit and found that most of the time the membrane gets ‘sticky’ from age and that causes many of the keyboard errors, like the appearance of stuck keys. It appears the peroxide removes that ‘sticky’ stuff.
Since I had 5 of these non-working keyboards, I removed the rest of them from their cases and submerged them all in the hot water / peroxide solution. Very much to my surprise, 4 of the 5 keyboards came back to life and work perfectly. The key seems to be to allow enough time for the keyboard to dry completely. I suggest waiting at least 24 hours after shaking out all the water etc.
I have no idea about the longevity of this but its been over a year and the keyboards still work. Like I said, worth a shot of if you’re only going to toss it. I attached a picture of the peroxide I used in case anyone wants to know. I got it from Amazon of course. Good luck !
