cchhrriiss11
Hi,
I'm working on a nice DECMate I just got, the whole system (VT278, Keyboard, RX02, DECWriter IV, complete manual set) is in really good shape. I've done some initial testing and it appears that the memory modules are bad. Each time I power the system on, it fails the POST on test number T6 (Main memory read/write). I've removed, cleaned the sockets and reseated each of the chips on the CPU board - including SIP the memory modules, with no improvement. I've also moved the memory modules around and changed the order, with no change in behavior. There was also no change in behavior/activity when trying each of the modules one at a time (thinking that there might be one bad one that is causing the POST to fail).
These memory modules seem to be very hard to find, anyone have any spares or have any tips on the troubleshooting?
Regards,
Chris
Regards,
Chris
