gnupublic
Hi,
Last year I got a ST-225 and build it into my DECMATE II. Then I installed OS278. Now I also installed CP/M80, DOS211 and MasterMenu, after I understood the concept of "Volumes" with Master Menu. I also created 3 further volumes to mount as RD51-RD53 (after "set handler RX01 RD5B").
Now I would like to mount these volumes in a batch script when starting OS278.
But I always get the same error, when running a very simple TEST.BI:
$JOB GREETINGS
.TYPE INIT.TX
$END
#BAD LINE. JOB ABORTED
This works under OS/8 without problems when just doing "SUBMIT TEST.BI".
But with the DECMATE II it will not run, also not with option /E.
A Batch with only $JOB and $END gives no ERROR, but with any command (.HELP, .DIR and so on) the ERROR comes up.
Would be great to get a hint....
Have fun,
Volker
$JOB GREETINGS
.TYPE INIT.TX
$END
Have fun,
Volker
