Defeating Tandy 1000 Detection
Great Hierophant
Massachusetts, USA
Many PC games autodetect when they are in a Tandy 1000 system and if so, will automatically use the Tandy video and audio hardware instead of other PC video adapters or the PC Speaker. I believe that virtually all Tandy-supporting games check a BIOS type byte to determine that they are being run on a Tandy and not an IBM PC/XT/AT. If so, could someone write a simple TSR-style program that will intercept the read and return an IBM byte instead?
How do you propose that somebody write a TSR that can intercept a read of a memory location?
Although I'm not sure I understand the intent I'd assume if possible you'd hijack/overwrite the memory location for the interrupt like most viruses?
..after I post that I realize you don't necessarily call an interrupt to read a memory location unless they do it that way. Either way I think you'd want to run it through a debugger to find what it checks. Then you could either patch the binary or I dunno if it'd be worth the effort trying to poke that address or reburn an eeprom.
That's my point. You can't write a TSR to intercept a memory read. You can write a TSR to do something at a timer tick, or to intercept a hardware or software interrupt. But not an arbitrary memory read.
The program has to be patched. Or you can patch that byte in the BIOS, as is done on some PCjrs. But a TSR is impossible.
I understand that it is impossible. What is possible is to burn the ROM with the ID byte replaced. Of course, by doing so you would make the programs that detect a Tandy machine using that byte unusuable in Tandy mode. Therefore, you would need two ROMs instead of one and use a switch to activate the proper ROM.
Presumably, the byte in question would be at F000:FFFE, as it is with the IBM PCs, but both the SX and HX BIOS ROMs I looked at have FF in that memory location, so there has to be another way.
I guess this is something you learned from the thread, because in your original message you had written this:
"If so, could someone write a simple TSR-style program that will intercept the read and return an IBM byte instead?"
Apparently it is returning the 'PC' value. Tandy probably defined a 'sub-architecture' value at a known location in BIOS which is what the software is looking for and using. The copyright string is another possibility.
PCjrs have a great solution for this problem - ROM cartridges that can replace (or patch) the system ROM.
What games do is check the BIOS for the string "TANDY". The ID byte on all Tandy 1000s (except the RLX and RSX) is FFh, same as the IBM 5150.
Now on PCjrs, the ID byte is FDh. Games like Jumpman, Troll's Tale, and Oil's Well (all released in 1984 before the Tandy 1000 had debuted), check F000:FFFEh for FDh, and if they find something different, they assume they're on a normal PC and will only run in CGA mode with speaker sound on Tandys.
