I have a PB Legend 20CD that mostly works - I've replaced the backup battery and added in a couple of sticks of RAM. It boots from the floppy into either MS-DOS 5 (the Packard Bell one) or 6.22, but it doesn't boot from the hard drive and as it turns out, I cannot get it to boot from a CF card either. It has one ISA slot open out of the three on the riser - one is taken by a standard sound card and the other by a Greystone quad IDE, ISA card (I'm guessing that isn't standard for a PB).
I've gone into setup and modified the setting for the board IDE channel 0 master to have User defined CHS of 993,16,63 to match the CF card capacity of 512 MB. When the DOS installer comes up for a floppy drive install, since it can't locate a suitable hard drive, I drop into DOS and try to fdisk /mbr the drive and it returns ' the master boot record was not written)
I have also tried using 4 different CF cards (a generic one, a SanDisk Ultra, a SiliconDrive and a Kingston), using two different CF adapters, two different floppy cables one of the CF adapters plugs directly into the MB. I even tried plugging into the Greystone card and disabling the MB IDE channels, but nothing has worked.
Any suggestions?
Any suggestions?
