Removed0
I bought a Dolch VPAC 386 but I can't get anything to display on the plasma screen.
The plasma display (a Panasonic MD480L640PG3) runs on high voltage DC and there's a boost converter inside of the PC, that is powered from a 12v line from the power supply. The boost converter has three output lines: HV+, HV- and Vcc-. It is currently outputting 178-180v DC when tested across HV+ to HV- and HV+ to Vcc-, and nothing across HV- to Vcc-.
The video card, a Paradise Systems PVGA1A-JK, will display to an external monitor. The edge connector on the card appears to be a regular old feature connector, and I'm about to test a different video card tonight (I had to order a 26 pin ribbon cable).
There's one more component, a small board that converts the feature connector output to the plasma display's input, it's got a couple of tants on it and a small IC (I need to look up it's function).
Does anybody have experience with plasma displays that can point me in the right direction? This is my first foray into the world of plasma display technology, and cannot locate a datasheet for that display, so I don't even know if the boost converter is working right. Or the PDP, or the mystery video converter.
Thanks!
Thanks!
