scommstech
- Joined
- Jul 16, 2007
- Messages
- 69
Hi
I'm trying to check out an old XT motherboard and have hit a problem.
Does anybody understand the memory refresh process that IBM's XTs
used.
The board uses the 4164 DRAM therfore there are 64000 memory cells
per chip.
The XT uses RAS/CAS and 16 bit addressing. I would expect RAS to use 8
Add bits 0-7 = 256, and CAS to use Add bits 8-15 = 256 thus giving a total
of 64000 memory cells.
The refresh only uses RAS every 2ms set up by the DMA. All 4 banks get RAS
at the same time. I believe that toggling RAS causes a cell refresh.
For all the 64000 cells to be refreshed each RAS toggle must have
an accompanying incrementing address 0 to 256. So 256 RAS pulses would
refresh to whole memory.
Using a logic analyzer on the faulty board the RAS pulse is accompanied by
a constant address. This I thought was the problem, ie the address not
incrementing. I put the analyzer on a good motherboard and it's the same,
ie constant address.
Where is my theory going wrong ???.
Can anybody throw some light on this.
Regards
Scommstech
used.
per chip.
Regards
Scommstech
