DS1216 chips (the DIP16) version are all over the place and seem to be readily available. I was looking at this, and wondering why nobody has made a quick PCB adapter for it (DIP28 socket on top, and pins on bottom) so we can adapt to a DS1216E.
Looking at the pinouts on the DIP16, and how they relate to the DIP28, I'm still missing some information (I don't have a unit to do this testing on, so have been going by the reference on this page and Maxim's data sheet https://pdfserv.maximintegrated.com/en/ds/DS1216-DS1216H.pdf.
So, five unknowns and these to potentially pick from on the DIP28:
Pin 26: VccB
Pin 27: WE* (but that looked already used?)
Anyone want to help contribute and correct? I'm in a bit of a brain fog, so I really need some help to double check these, especially if you have one of these and can meter out the pins.
Thanks!
DS1216 PIN/DESC DIP28 PIN/DESC
1 X1 UNKNOWN, goes to pad
2 X2 UNKNOWN, goes to pad
3 WE* PIN 8, WE*
4 BAT1 n/c - goes to +3V battery
5 GND PIN 14, GND
6 D PIN 10, A0
7 Q PIN 11, DQ0
8 GND PIN 14, GND
9 ROM/RAM* UNKNOWN, goes to pad
10 CE0* PIN 20, CE0*
11 CE1* UNKNOWN, goes to pad
12 OE* PIN 22, OE*
13 RST* PIN 1, RST*
14 BAT2 n/c - goes to +3V battery
15 Vcc0 UNKNOWN, goes to pad
16 Vcc1 PIN 28, VCC
Pin 26: VccB
Thanks!
