Email on a 286?
Haemogoblin
Sheffield, England
I was wondering how possible this might be on my little Sharp portable. I've used up the single ISA port with the IDE card, so i'm restricted to serial/parallel ports for communication.
I'm working with a 286 CPU and 640kb of ram.
--james
Dunno how common they are in England, but Xircom did make a parallel port ethernet adapter that works in MS-DOS. If you get one of those, you'd be able to use the CHASE e-mail client, written by our own Mike Chambers: http://rubbermallet.org/software/chase.html
I don't think CHASE can do any sort of encryption though.
I've seen these before somewhere, what are the system requirements?
I was using the system today and noticed i was wrong, the system actually has 512kb of ram, i'm not certain if this is upgradeable or how i'd do it.
James
When you have a serial port you can always hook up a modem, dial in to an ISP and read email through TelNet.
It does have a serial port, i dont really fancy the modem route, as it will incur a charge. And when i've got a fully working broad band connect, i dont see the point in using the phone line :p
James
The Xircom adaptors work on anything with a parallel port, even down to an 8088. The drivers take a few KB, but you only need to load them when needed, so it isn't a problem most of the time, and the basic packet driver is very small anyway.
You need somewhere to tap a power supply from though. The parallel port by itself can't supply enough, so they come with a cable to take power from a PS/2 keyboard/mouse port, or you can use an AC adaptor.
I'm pretty sure I've got one somewhere, which you can have for the price of postage if you're interested.
