High_Treason
This one has got me beat (and I'd be willing to bet I have forgotten something stupid), I have a K5-based system which ran fine aside from a dodgy hard drive (which has been dodgy for almost a decade) - needless to say I got tired of read/write errors and replaced it with another drive which has hardly been used.
I installed Windows 95, the same version it was running before (from the same CD even, 4.00.950) but there is a small problem. I can run Windows fine, provided I don't load EMM386, unfortunately I need that in DOS sometimes. I attempted to replace it with JEMM386 but it still runs slow.
I used step-by-stem confirmation to chech it out, basically it gets to loading EMM386 (or equivalent) and just sits there for a few minutes, the CPU and COAST get very hot once EMM386 is loaded (and I'm using a Socket 370 Celeron heatsink, this is a K5-PR100ABQ, gray) and attempting to load any program after this (even EDIT) results in further waiting times. Windows will usually boot slowly and things speed up once in the OS although it did give me an error message once, unfortunately I was watching something whilst this happened and I caught it just as the "It is now safe to turn off your computer" message appeared.
Any ideas? I can post the contents of the CONFIG.SYS / AUTOEXEC.BAT etc if you wish as they are heavily modified (based on a template I wrote for convenience sake) although I don't think the loading order is wrong. I had 48MB of RAM installed, but the readout on MEM was weird, so I have reduced it to 32M as there seemed to be trouble working with RAM above this, although tests with 16MB yielded no improvement (if anything it was slower).
