EMS and XMS memory distribution on a 286 motherboard
I found information on a Russian site with the same motherboard and which has the same problem as me, apparently it works well with 1MB, with 4MB or 2B there is a problem of stability and xms and ems memory.
Message from a person that has a same motherboard that me:
It works fine with installed memory up to 1MB, then it looks like a conflict of something in the hardware, tk. the inclusion of hymem.sys and, accordingly, access to extended memory greatly affects the stability of the work. With 1 MB everything is perfect.
I contacted the seller, he told me to send him the ram, he refunded me, and he will also check that it works by doing further tests,
we will say that the problem is solved.
In conclusion this model of motherboard is not quite stable and is quite fragile, in any case with this chipset, there is the same card with the heatland chipset which looks more stable.
is it possible to configure the memory just with XMS (hymem.sys only), without EMS ?
because in checkit the tests pass except High Addr Lines, the computer hang,
is what to put imperatively DOS=HIGH in the config.sys?
if I put DOS=HIGH, the EMS and High Addr Lines tests failed and when I don't put DOS=HIGH,
the computer waits indefinitely on High Addr Lines.
The error seems to be related to the infamous A20 line:
To access extended/high (first 64k of extended memory) memory you need to enable it. Unfortunately everyone had his own method to it ... So Either you haven't configured properly the board jumpers or the board is using a particular method to enable A20 line:
By the way, Are you sure that the EMS driver you are using is correct? Here you have a collection of EMS drivers including one for Winbond:
thank you for this information, I have not tested it, I will.
I will see this drivers to for winbond.
Thank you
Speaking of Microsolutions para drives (guessing 4x), think the "recordable/rewritable" units work with the same driver?
No idea. Never had to use them.
The Docs should give you a clue I'd imagine. The breif "Quick Start Guide" pamplet mentions files named CDGUIDE.TXT and CDGUIDE.DOC contain the BackPack CD-ROM User's Guide.
Generally speaking, XMS support does not depend on any chipset-specific features. It is just the CPU outputting memory addresses above 1 MiB.
The only prerequisite there is enabling A20 gate. This is typically done using keyboard controller, although some chipsets and BIOSes offer "fast A20" option implemented in chipset. If that option is present in the BIOS, disabling it usually provides better compatibility. Also, HIMEM.SYS tests the XMS memory, so if it loads without any errors, the memory is probably OK.
EMS on the other hand is a memory paging technique implemented in the chipset (or a separate logic on in case of an ISA EMS board), so it is very much chipset/vendor specific, particularly for 8088/86/286 (in 386 and up EMM386 can be used to emulate EMS using Virtual 8086 mode).
To make things easier, unless you know you need EMS, just use XMS. With DOS >= 5.0, you should be able to use DOS=HIGH, which will use the first 64 KiB above the first megabyte to load parts of DOS and will save the lower 640 KiB (conventional memory) for applications.
Regarding Windows 3.1 on 286:
- It only works in "Standard Mode", which utilizes 286 protected mode, and can use XMS memory (no 1 MiB memory limit, no need for EMS)
- When you run DOS application, Windows actually resets the CPU, and runs it in real mode (vs. protected mode that Windows standard mode uses), there are no benefits in running DOS applications from Windows (on 386 / Windows 3.1 Enhanced Mode runs DOS in a VM86 mode, which allows it to co-exist with other Windows applications) . On a 286, I personally would run DOS applications from DOS...
Probleme resolved for my problem hanging checkit and command dos.
i have put another ram and all is ok, all work fine now.
for EMS I have to use the winbond drivers and activate EMS in bios except that all the memory is allocated to EMS so it is less interesting. I would only use XMS.
