The southbridge in this machine is a VT8231. According to the datasheet there are registers there that can be flipped on to enable UDMA. My storage solution supports UDMA. I have verified this using another machine.
Thanks to some VERY nice Discord users, I now have a modded BIOS for my machine that someone programmed an ISA Expansion/Option ROM for and that ROM flips the necessary bits to enable UDMA. I can confirm this works by using WPCREDIT and viewing the bits on the appropriate registers. However, UDMA is still not enabled. On my working UDMA system I can simply use the old DOS program Spinrite to go look at the details of the drive and it confirms whether or not UDMA is in use. When I try that on this problem machine, it says it is not being used. I also have tried viewing in device manager (Both WinXP and Win2k) if UDMA is enabled but it is not.
What else could we try here?
