Epic Plus Programmer - EPROM software
lucasdaytona
Brasil
Hi, does anyone knows this programmer?
I bought it yesterday, will arrive within 2 weeks. No software, cable or manual, just a very good price. It does powers on, the previous owner said it used to burn 27C400 with no problem (which was the main reason for buying this, I currently have two Leaper 3C that could not deal with 40 pin EPROM, and I need to burn one for a AMIGA 2000). The guy also said it worked with almost any software from that time. Do you guys recommends any MSDOS/W9X software? I'm reading the docs from Ponyprog, but unsure. Also, it does use a DB25 port, should I build a standard parallel cable? When it arrives I will open it up and post a picture here. Some info that maybe help, here.
Thank you!
