Epson hx20 with expansion unit help with command for memomry
Junior Ramos
Hello,
I have an Epson HX20 with memory expansion but I need to know how can I check if all memory are installed, I read the user guide but do not found any command like
printmem.
Any help please.
Thanks
I found the command is print fre(0), but my computer has 16k plus 16k in the expansion but the command show only 21083,
any one know why?
Thanks
I check the switched on the expansion board a set for 32k, But I need to move the Skiwriter ROM to the expansion board in order to working properly.
The computer was Initialize and I see in the menu the Skiwriter but when try to run just appear:
Trap!
A=00 B=00 X=601E
C=C0 S=04AD P=601E
Any help?
Thanks again
I think fre(0) returns free memory, in your case 21083. So the rest of the installed
memory is probably in use (by the operating system?).
...>I found the command is print fre(0), but my computer has 16k plus 16k in the expansion but the command show only 21083,
any one know why?
Thanks
