Hey All,
recently acquired a 386is overall pretty good condition. Looks like the bios battery leaked and i removed it. On the battery it indicated 3.6v a varta 3.6v 60mah ni/cd battery. I have a few LIR2032 laying about which are 3.6v, I just tested one with my multimeter and it indicated 3.9v. would that be ok to install in place of the old battery or is that too many volts?
I will try to add pictures but before i go off the deep end just wanted to see what I should or need to do. it has a vga card, a drive card comes with a 5.25 floppy and the 3.25 floppy drive it has an MFM hard drive but i believe that has failed. I can boot into bios and I snagged a keyboard that has a mouse below the spacebar and I was wondering what adapter piece i'd need to get that connected. it looks like a serial port cable.
Essentially I want to add / replace the storage I've seen adapters for ISA to Compact flash? if that is the best option could anyone recommend a brand model?
I snagged a coprocessor since when i booted into the bios it indicated no coprocessor found its a Math cosx which i believe should work i haven't tried it yet.
I'm not new to computers/computing but these computers are when I was a little kid so a lot of it is foreign to me, i can do dos, windows 95 and things like that but in terms of the hardware space i'm a bit foggy or not knowing when it comes to this. i've googled and found some articles for the everex 386is but most seem to have a daughter board where the coprocessor goes while mine is on the main board.
Kind of ranting here so i'll just post pictures. any insight would be appreciated. thank you.
