I'm trying to resurrect a basket-case PC compatible that I've had for ages. It's a 486 but this is more of a general hardware question.
The motherboard has a soldered rechargeable battery on it which has long since stopped working. It has a 4 pin connector for an external battery. (In the picture the four pins for the external battery are on the right side.)
The resistors and diodes between the battery and the jumpers make me curious. I didn't buzz them out fully but at least some of those resistors and diodes are connected to the external battery connector. Which implies a non-rechargeable battery is expected there. The resistors might also be to drop the voltage, but I still don't know if it wants 4.5 or 6v.
I guess I could disable the internal battery using the jumper, then look for positive voltage on the external battery connector. That would also answer the rechargeable vs. non-rechargeable question.
Thoughts?
- What's the correct type of battery to use here - rechargeable or non-rechargeable?
- And at what voltage rating?
Thoughts?
