Ah, I thought we were talking about ISA cards.
If you're wanting PCI, it's a totally different game. Just get a Trio64V+ and be done with it.
S3 928 is probably a poor choice for PCI...I don't know if that one supports PCI natively. Either way it's not a mature solution.
I see.
Well, I could use expertise for ISA cards too, here are the 2 questions:
1) While the Pentiums are PCI-based, the 486 is ISA only. I'd apply your suggestions for the 486 (Compaq Prolinea 4/66 DX2). However, in that case, the Whatever ISA SVGA shall have to compete against the ET4000/W32p that is built on the motherboard under a "local bus" (quoting the mobo spec sheet). In other words, it gotta be worth it! If this "local bus" is a 32 bit 33 MHz one, the ISA card will have to compete against basically a kind of a "PCI" ET4000/W32p.
2) On the PCI Pentiums, what about S3 Vision 968 and/or Cirrus GD5446BV?
Thanks again!
