bhtooefr
Got an interesting issue, where REMM.SYS 4.70 is wiping out my SMC 8003WC ethernet card's RAM base address (moving it from CE00h to 8000h - yeah, nasty) - apparently its probing for AST EEMS cards is not actually compatible with the SMC 8003WC's EZSetup protocol.
None of the docs I've found say how to manually specify I/O addresses in REMM.SYS, though.
Am I going to have to figure out how it's probing, and manually patch out the probing?
Edit: Also, verified that it's only causing problems on a cold start. If I bring the machine up with REMM.SYS commented out, then uncomment it and reboot, it treats it as a warm boot and doesn't do a full memory test. That memory test seems to be when it's damaging the ethernet card's config. If it helps, the card is a SixPak Premium with 1024 KiB installed. And, I've tried moving the I/O address from 0218 to 0258, no change in symptoms.
Ethernet card is configured for 280h to 29Fh, IRQ 2, RAM base CE00h, and I really don't want to use the jumpered configs (the only one I even could use is 280h I/O base, IRQ 3 (conflicts with COM2: if I ever get that installed), RAM base D000h (very much not optimal)).
