Hans01
@dano
You have a lot of options to connect a "harddisk" to your Model II (Model 12, Model 16, 6000)
At first there is the HxC adapter which can be used on the Model II family and the Model 1,3,4 and 4P
To connect the HxC to the Model II, the best way is to use the "50 Pin Floppy to 34 Pin Floppy Converter Board" from NF6X to interface
the HxC in an easy way.
The next option is to use the Lo-Tech ide adapter. You can use it on all models mentioned above.
To interface this adapter on a Model II you can use a Model II harddisk controller Type 2,
the hans-01 or hans-02 adapter see "The Right Stuff" site,
or the new DOM adapter which combines the functionality of the Lo-Tech adapter and the hans-02 adapter.
At this moment only available for LSDOS 6.32 and Lifeboat CP/M 3 (With master and slave functionality, software interface by JonB)
You can download all bootable disks for all options on all devices. There is an image of a DOM with all kinds of Model II software available for download.
You can find all info about this subject on this site. Search for Model II, DOM, HxC, hans-01, hans-02, Lo-Tech, repository, NF6X.
The possibility to use the FreHD with the model II is a long running project and don't expect soon results.
